197 user(s) are online (145 user(s) are browsing Forums)
96LT4CE AC programmer pic request
NWI
112 Posts
Anyone have a picture of the 1996 AC programmer board?
Front and back?
Posted on: 2014/7/19 20:59
My shoulder hurts bad
-=Jeff=- Re: AC programmer pic request
Bartlett, IL
573 Posts
front:
Back
Posted on: 2014/7/20 2:22
-=Jeff=-
1990 Corvette ZR-1 #1051
96LT4CE Re: AC programmer pic request
NWI
112 Posts
thanks Jeff.
I'm going to try and work on my programmer and wanted to see what I was in for. From a chip stand point it doesn't appear that there are many. Between the caps, diodes and resistors i hope I can track down the bad ones and replace
Posted on: 2014/7/20 4:46
Matatk Re: AC programmer pic request
22806 Posts
Did you troubleshoot with section 8a and determine it was the programmer?
Posted on: 2014/7/20 14:00
NWI
112 Posts
It's pretty funny in that section as the trouble shooting tree ends up with replace programmer regardless of how you answer the questions!
The only difference is you either make it there in 3 answers or 6.
Posted on: 2014/7/21 10:50
22806 Posts
Lol...have you gotten a chance to pull it yet? I know on the older ones there can be bad solder joints, etc, causing the problems.
If you replace it, look for one from a 95 because the nipples that the vacuum hoses connect to are hard plastic instead of soft. The 96 model specifically has a problem with those soft ones closing up and not allowing you to switch the position of the air vents.
Posted on: 2014/7/21 11:36
NWI
112 Posts
I'm going to try and pull it, boy does that sound wrong, later today.
I know 96 is a one year only programmer, but can it be replaced with any 90+ module?
Posted on: 2014/7/21 17:16
Bartlett, IL
573 Posts
yeah i think so.. the one in the picture I believe is from a 96 and I had it in a 1990 and it worked..
Posted on: 2014/7/21 19:20
-=Jeff=-
NWI
112 Posts
Gonna be pulling the drivers seat in the next hour or so, No way I'm fitting down there with it in place!
Posted on: 2014/7/21 19:45
pianoguy Re: AC programmer pic request
Midget contortionists are best-suited for removing the programmer. It is held on by an annoying little push-nut - I managed to grab an edge of it with a needle-nose pliers and twist it until it broke off, and used a nylock nut when I reinstalled it. Then, once I got the programmer loose, there was barely any slack in the vacuum lines, so that was delightful as well. Good luck!!
Posted on: 2014/7/21 20:27
NWI
112 Posts
MFPITA
Posted on: 2014/7/22 0:12
22806 Posts
Did you get it out?
Posted on: 2014/7/22 2:32
22806 Posts
This is some good info on the collapsing nipples I was talking about:
http://m.corvetteforum.com/c4-tech-pe ... -problem.html?styleid=140
Posted on: 2014/7/22 2:38
NWI
112 Posts
I wish it was as simple as a pinched vacuum line
Posted on: 2014/7/22 4:58
