96LT4CE | AC programmer pic request | ||
Anyone have a picture of the 1996 AC programmer board?
Front and back? |
Posted on: 2014/7/19 20:59
My shoulder hurts bad |
-=Jeff=- | Re: AC programmer pic request | ||
front:
Back |
Posted on: 2014/7/20 2:22
96LT4CE | Re: AC programmer pic request | ||
thanks Jeff.
I'm going to try and work on my programmer and wanted to see what I was in for. From a chip stand point it doesn't appear that there are many. Between the caps, diodes and resistors i hope I can track down the bad ones and replace |
Posted on: 2014/7/20 4:46
Matatk | Re: AC programmer pic request | ||
Did you troubleshoot with section 8a and determine it was the programmer?
Posted on: 2014/7/20 14:00
10-4
It's pretty funny in that section as the trouble shooting tree ends up with replace programmer regardless of how you answer the questions! The only difference is you either make it there in 3 answers or 6. |
Posted on: 2014/7/21 10:50
Lol...have you gotten a chance to pull it yet? I know on the older ones there can be bad solder joints, etc, causing the problems.
If you replace it, look for one from a 95 because the nipples that the vacuum hoses connect to are hard plastic instead of soft. The 96 model specifically has a problem with those soft ones closing up and not allowing you to switch the position of the air vents. |
Posted on: 2014/7/21 11:36
I'm going to try and pull it, boy does that sound wrong, later today.
I know 96 is a one year only programmer, but can it be replaced with any 90+ module? |
Posted on: 2014/7/21 17:16
yeah i think so.. the one in the picture I believe is from a 96 and I had it in a 1990 and it worked..
Posted on: 2014/7/21 19:20
Gonna be pulling the drivers seat in the next hour or so, No way I'm fitting down there with it in place!
Posted on: 2014/7/21 19:45
pianoguy | Re: AC programmer pic request | ||
Midget contortionists are best-suited for removing the programmer. It is held on by an annoying little push-nut - I managed to grab an edge of it with a needle-nose pliers and twist it until it broke off, and used a nylock nut when I reinstalled it. Then, once I got the programmer loose, there was barely any slack in the vacuum lines, so that was delightful as well. Good luck!!
Posted on: 2014/7/21 20:27
MFPITA
Posted on: 2014/7/22 0:12
Did you get it out?
Posted on: 2014/7/22 2:32
This is some good info on the collapsing nipples I was talking about:
http://m.corvetteforum.com/c4-tech-pe ... -problem.html?styleid=140 |
Posted on: 2014/7/22 2:38
I wish it was as simple as a pinched vacuum line
Posted on: 2014/7/22 4:58
