249 user(s) are online (225 user(s) are browsing Forums)
bogus Failed Smog....UPDATED!!! PASSED SMOG!!!
Rather surprising, really...
92 Coupe, LT1 (from a 96), new California legal Magnaflow cats, LTCC.
It ran real lean at 25 MPH. The NoX went nuts... went from 300 and something @ 15 MPH to 650 at 25 MPH.
The Lambda calculator indicates lean.
I am thinking:
1. Bad vacuum to the EGR
2. The air pump, being disconnected, isn't helping
3. Loose O2 sensors
Posted on: 2014/10/10 15:59
Edited by bogus on 2014/10/18 22:34:50
Matatk Re: Failed Smog....
22803 Posts
Posted on: 2014/10/10 18:03
BrianCunningham Re: Failed Smog....
for a second I thought they gave you grief about the LTCC
Posted on: 2014/10/10 23:22
Schrade Re: Failed Smog....
I am thinking:
3. Loose O2 sensors
Lean burn = hot burn; hi NOx's.
Lean burn could be 'rich' (long pulsewidth), with poor atomization from low fuel pressure, and confused O2 readout...
Posted on: 2014/10/11 2:59
bogus Re: Failed Smog....
They do... but normally, it passes with flying colours...
I think that my assessment is correct.
I am going to check vacuum to the EGR, then check the fuel pressure... It might be low, if so, that would cause this. I was adjusting down to compensate for the different flow rates of the various injectors... but I don't think I need to do that with these newer style matched injectors.
Also, make sure the air pump is up and running ok.
Posted on: 2014/10/11 15:40
istter1 Re: Failed Smog....
Bakersfield Ca
2336 Posts
Like we in California say welcome DMV loves you. make sure the air pump is up and running.
Posted on: 2014/10/11 18:29
Carol Burnett
no kidding...
Posted on: 2014/10/11 18:40
ok... checked lotsa stuff, still one more thing to check.
However, the various vacuum lines that feed to the EGR were compromised.
The hard line was fitted to a rubber line, and the rubber line was just big enough to not allow a seal to occur. If I was losing vacuum around that connection, well, gee, by all means, I had a problem!
Posted on: 2014/10/11 22:33
Bakersfield Ca
2336 Posts
Good luck at the retest
Posted on: 2014/10/14 4:04
Carol Burnett
Are you sure that EGR vac supply was 'broken'?
Seems to me that ECM looks for vacuum to hold for x seconds (with EGR solenoid valve closed (or open?) ), and if it doesn't hold for x seconds, then you get a 32 DTC SES, or it comes up as H DTC...
Isn't that how it operates?
Posted on: 2014/10/15 12:39
To a degree, but if the bleed off is so slow, it might not notice...
At the same time, I am going to ramp up the fuel pressure. If that's a touch low, then it will cause a lean condition.
Posted on: 2014/10/15 20:03
NelsonV Re: Failed Smog....
Sunny Southern CA
245 Posts
Codes? Or just failed the sniffer/dyno? I have your scanner in my trunk.
Posted on: 2014/10/16 0:03
that scanner won't help my Vette... It helps the suburban... thanks, tho.
no codes, just a rise in NoX and a failed test.
Posted on: 2014/10/16 1:11
Maybe before adjusting fuel pressure (you have adjustable FPR?) , note that ANY vac leak will affect stock FPR response to fuel pressure.
Fuel pressure is critical to get good atomization...
Posted on: 2014/10/16 12:46
That's my next test... and yes, I have an AFPR, with a dedicated gauge on the fuel rail.
Posted on: 2014/10/16 15:58
Posted on: 2014/10/16 20:16
I have "new" magnaflows... under 2 years old, 15k miles, CA OBDII compliant. They better work...
Posted on: 2014/10/16 23:44
Bakersfield Ca
2336 Posts
I am curious to see how the new Exhaust system with one less cat works. in California. We have crazy rules/87 has
two pre cats and the third that collects garbage. The California cat tax stamp is a joke. If your smog guy can't pass it just drive up north Andy and see my smog guy
Posted on: 2014/10/17 3:14
Carol Burnett
Oh, I will pass... no question about that!
The LT1, LT4 and LT5 have one cat on each bank.
I hate the L98 setup...
Posted on: 2014/10/17 5:47
22803 Posts
Double check that gauge. I had one that was 8 psi low and it was driving me nuts trying to troubleshoot the problem when it was the gauge all along.
Posted on: 2014/10/17 11:43
it passed. Very nicely.
I am pretty sure it was the vacuum line, if nothing else, it was introducing more air into th intake.
Posted on: 2014/10/18 20:26
Bakersfield Ca
2336 Posts
Well done Andy
Posted on: 2014/10/19 1:04
Carol Burnett
bogus Re: Failed Smog....UPDATED!!! PASSED SMOG!!!
thanks!
Can't over think this stuff, ya know?
Posted on: 2014/10/20 16:31
