152 user(s) are online (119 user(s) are browsing Forums)
istter1 87 vet clutch pedal removal
Bakersfield Ca
2336 Posts
The stud on the pedal that hold master cylinder rod on is shot. I was trying to find a Diagram of the assembly. I have found a gm diagram that looks like what I need to do but not sure if it is the same on mine.
Not sure but I think only one bolt holds it in place. Because of high blood pressure and getting sick as a dog on my back I want to be as ready as possible to do this
The stud on mine looks a lot worse then this one. The hole on the push rod is almost broken through
Steve
jpg  47842251d1416523042-clutch-pedal-removal-20141120_173559.jpg (40.98 KB)
5144_5522adbcda513.jpg 800X600 px
jpg  47842398d1416590195-clutch-pedal-removal-20141121_121402.jpg (70.49 KB)
5144_5522add2a0177.jpg 800X600 px
Posted on: 2015/4/6 16:02
Carol Burnett
bogus Re: 87 vet clutch pedal removal
it's on the same bracket as the brake pedal... I will dig into my FSM tonight and send some pictures.
Posted on: 2015/4/6 17:02
I hope you are feeling better!!!
Posted on: 2015/4/6 17:03
istter1 Re: 87 vet clutch pedal removal
Bakersfield Ca
2336 Posts
Thanks Andy now were down to just diet and exercise
Extreme Harding of the arties
Posted on: 2015/4/6 18:23
Carol Burnett
EngineDoctor Re: 87 vet clutch pedal removal
La Habra Ca.
791 Posts
Hope you feel better as well Steve !
Posted on: 2015/4/6 22:53
Bakersfield Ca
2336 Posts
MAKING SON REMOVE pedal tried got dizzy and sick. It is a pain in the ass. I am final installing the Wilewood 3/4 clutch master cylinder for the hydraulic throw (been using stock 1/2 requires 3/4 to work and last ) out bearing and this is when we found the push rod stud destroyed. I BELEIVE ITS 3/8 Not certain were to get a new one but I will fab up something.
My son AJ says high. He really loves the 383 you built for me
Posted on: 2015/4/6 23:03
Carol Burnett
La Habra Ca.
791 Posts
Thanks Steve !! Nothing makes me happier than a Happy customer !... Hi to your Son!
Posted on: 2015/4/7 4:26
Bakersfield Ca
2336 Posts
Pedal repaired bushing added good fit. Will when I make son get under dash LOL install pedal. Still get sick on my back hate it.
Pictures of the repair and bushing used to install 3/4" master cylinder Wilwood
Well tried 3 computers it will not let me up load pictures again
Posted on: 2015/4/9 4:47
Carol Burnett
that's annoying... I am in process of upgrading this pig...
glad you got the pedal fixed!!
Posted on: 2015/4/9 17:00
Bakersfield Ca
2336 Posts
easy part Andy
hard part will giving my son directions on reinstalling the pedal.
http://www.corvetteforum.com/forums/c ... utch-pedal-removal-2.html
Posted on: 2015/4/10 2:02
Carol Burnett
Bakersfield Ca
2336 Posts
Wow after fabing push rod pedal push rod bracket going everywhere to make brake lines 1/4" lines fit adapter on Wilwood 3/4" clutch master cylinder. I am so impressed with the feel of the pedal I think someone else must have done the job for me.
Next install the LT1 exhaust pipes. Wish there was someone near by to paint my vet. Everyone wants a small fortune to do the job.
Posted on: 2015/4/25 20:46
Carol Burnett
Schrade Re: 87 vet clutch pedal removal
You needing parts? I have clutch pedal / mount bracket / assembly parts from the Z, from auto conversion...
PM @ me here.
Posted on: 2015/4/25 21:44
Bakersfield Ca
2336 Posts
PM @ me here.
Thanks just replaced all
Steve
Posted on: 2015/4/26 4:20
Carol Burnett
CentralCoaster Re: 87 vet clutch pedal removal
If I keep my vette, I think I'll just do sanding and prep and disassembly and body work and then trailer it to maaco and let them shoot it.
Posted on: 2015/4/27 6:03
