istter1 | 87 vet clutch pedal removal | ||
The stud on the pedal that hold master cylinder rod on is shot. I was trying to find a Diagram of the assembly. I have found a gm diagram that looks like what I need to do but not sure if it is the same on mine.
Not sure but I think only one bolt holds it in place. Because of high blood pressure and getting sick as a dog on my back I want to be as ready as possible to do this The stud on mine looks a lot worse then this one. The hole on the push rod is almost broken through Steve |
Posted on: 2015/4/6 16:02
bogus | Re: 87 vet clutch pedal removal | ||
it's on the same bracket as the brake pedal... I will dig into my FSM tonight and send some pictures.
Posted on: 2015/4/6 17:02
I hope you are feeling better!!!
Posted on: 2015/4/6 17:03
istter1 | Re: 87 vet clutch pedal removal | ||
Thanks Andy now were down to just diet and exercise
Extreme Harding of the arties |
Posted on: 2015/4/6 18:23
EngineDoctor | Re: 87 vet clutch pedal removal | ||
Hope you feel better as well Steve !
Posted on: 2015/4/6 22:53
MAKING SON REMOVE pedal tried got dizzy and sick. It is a pain in the ass. I am final installing the Wilewood 3/4 clutch master cylinder for the hydraulic throw (been using stock 1/2 requires 3/4 to work and last ) out bearing and this is when we found the push rod stud destroyed. I BELEIVE ITS 3/8 Not certain were to get a new one but I will fab up something.
My son AJ says high. He really loves the 383 you built for me |
Posted on: 2015/4/6 23:03
Thanks Steve !! Nothing makes me happier than a Happy customer !... Hi to your Son!
Posted on: 2015/4/7 4:26
Pedal repaired bushing added good fit. Will when I make son get under dash LOL install pedal. Still get sick on my back hate it.
Pictures of the repair and bushing used to install 3/4" master cylinder Wilwood Well tried 3 computers it will not let me up load pictures again IMG_20150408_180829.jpg C:\Users\Steve\Pictures\IMG_20150408_180850.jpg.jpeg C:\Users\Steve\Pictures\IMG_20150408_183513.jpg.jpeg |
Posted on: 2015/4/9 4:47
that's annoying... I am in process of upgrading this pig...
glad you got the pedal fixed!! |
Posted on: 2015/4/9 17:00
hard part will giving my son directions on reinstalling the pedal. http://www.corvetteforum.com/forums/c ... utch-pedal-removal-2.html |
Posted on: 2015/4/10 2:02
Wow after fabing push rod pedal push rod bracket going everywhere to make brake lines 1/4" lines fit adapter on Wilwood 3/4" clutch master cylinder. I am so impressed with the feel of the pedal I think someone else must have done the job for me.
Next install the LT1 exhaust pipes. Wish there was someone near by to paint my vet. Everyone wants a small fortune to do the job. |
Posted on: 2015/4/25 20:46
Schrade | Re: 87 vet clutch pedal removal | ||
You needing parts? I have clutch pedal / mount bracket / assembly parts from the Z, from auto conversion...
PM @ me here. |
Posted on: 2015/4/25 21:44
Thanks just replaced all Steve |
Posted on: 2015/4/26 4:20
CentralCoaster | Re: 87 vet clutch pedal removal | ||
If I keep my vette, I think I'll just do sanding and prep and disassembly and body work and then trailer it to maaco and let them shoot it.
Posted on: 2015/4/27 6:03
