249 user(s) are online (198 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
istter1 Windshield just cracked.87 vet
Bakersfield Ca
2336 Posts
Wow was washing off the fifth wheel 85 degrees out and just splashed the vet. Full length crack down the middle of the windshield.
Are the windshield hard to come bye and will I need an installer to put it in. Are getting seals that work easy to find. Is this a hard project?
I am good at breaking glass.
Steve
Posted on: 2015/5/25 23:59
Carol Burnett
CentralCoaster Re: Windshield just cracked.87 vet
Google my thread on CF. Mine is still a mess and it pisses me off to no end when I think about it.
There's a lot of ways to screw it up. I would not do it again unless I could verify the installer has done it before, and check his work.
I know how to do it myself but i don't have the tools.
You could try removing the weatherstrip yourself and cut it away from any overglue, and locate the screws for the metal trim, and try and remove those 3 pieces undamaged. You may want to get a new dust seal between the dash pad and glass. Use some good uv protection on it or it will disintegrate quickly again. Same for any new weatherstrip. The gm stuff I used was garbage. I should have tried the Willcox.
Posted on: 2015/5/26 2:25
The metal trim determines how high the glass should sit above the frame. If it is too low, they don't fit flush and water goes under them and behind the weatherstrip, if it is too high, the wipers won't fit under the hood. If they start drilling new holes, then its not lined up.
Posted on: 2015/5/26 2:32
Edited by CentralCoaster on 2015/5/26 4:44:41
Edited by CentralCoaster on 2015/5/26 4:45:26
Matatk Re: Windshield just cracked.87 vet
I know Kevin had trouble with his install, but someone else just had one installed with no issues. They are easily available at most glass places.
Posted on: 2015/5/26 3:15
TommyT-Bone Re: Windshield just cracked.87 vet
Find a reputable shop with some veteran installers. They should be able to handle it. Glass is available I believe from PPG. Had my 91 done a couple of years ago. No issues. Like I said, it was an experienced, well seasoned installer.
Posted on: 2015/5/26 12:24
"Oh yeah, we do those all the time."
Posted on: 2015/5/26 17:40
Research. Ask around.
Posted on: 2015/5/26 19:10
bogus Re: Windshield just cracked.87 vet
McJacks Corvette in Santa Ana. I know it's a haul, but they did mine... and it's fine.
Plus, he is hooked up with the insurance companies for glass replacement.
Posted on: 2015/5/26 23:44
istter1 Re: Windshield just cracked.87 vet
Bakersfield Ca
2336 Posts
talked to a friend at the Chevy dealer and they recommended a glass shop
My quote $250
Posted on: 2015/5/29 20:38
Carol Burnett
Fair price. They charge more if the bill goes to the insurance company. Just sayin ......
Posted on: 2015/5/29 23:41
Bakersfield Ca
2336 Posts
Wow what a fun job tool them an hour
very careful did a great job.
I sat in the Basque restaurant Wool Growers next door and enjoyed great food.
Always go to a shop with a dog roaming the building
he was checking my vet out
jpg  bobs.jpg (12.99 KB)
5144_556fcebfeef04.jpg 217X395 px
Posted on: 2015/6/4 4:07
Carol Burnett
pianoguy Re: Windshield just cracked.87 vet
Good to hear, hope I'm as lucky when the time comes. Mine doesn't have any cracks, but a couple little chips and a bajillion annoying little pits.
Posted on: 2015/6/4 12:52
