194 user(s) are online (162 user(s) are browsing Forums)
CentralCoaster Check out this bitchen C4 die-cast.
https://www.youtube.com/watch?v=Vi78q4_VL18
They have a red with tan interior, and a black with red interior. Exact match for an 1986-1987. 1/18 scale. I think they're about $180 though. I used to build models but who's got time for that anymore.
Roof comes off too, but the windows don't seem to go down.
You can even put in your winking headlight to match your real corvette.
It looks like it might even have working lights, not sure.
Posted on: 2015/7/16 18:17
BrianCunningham Re: Check out this bitchen C4 die-cast.
Sweet!
Posted on: 2015/7/16 18:30
GRIS Re: Check out this bitchen C4 die-cast.
OKLAHOMA
7712 Posts
LOVE IT. BUT NOT $180'S WORTH OF LOVE :-)
Posted on: 2015/7/16 19:09
hcbph Re: Check out this bitchen C4 die-cast.
269 Posts
If it's $180, the least they could do is have left and right rims rather than the same ones on both sides IMO.
Posted on: 2015/7/21 11:05
pianoguy Re: Check out this bitchen C4 die-cast.
Pretty awesome detail, indeed!
Posted on: 2015/7/23 0:52
