305 user(s) are online (266 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
BrianCunningham Engine cradle for an LT1
Ordering up an engine cradle to store my old engine
Site says one for a small block wouldn't fit an LT1/4 engine
Includes standard wheels and Grade 5 fasteners. Will not fit early blocks without side motor mounts. Does not fit LT1 engines.
That true? New one on me.
Is so, what are you using?
Posted on: 2015/7/22 17:38
bogus Re: Engine cradle for an LT1
it will... they are idiots.
all you need are a cheap set of old style motor mounts, not the new rubber cylinder things we have.
The block bosses are the same.
About $4.00 each at Rockauto. I am assuming his cradle has the bracket on it to accept the mount.
The brand is DEA and the part # is A2713.
Posted on: 2015/7/22 18:19
BrianCunningham Re: Engine cradle for an LT1
Posted on: 2015/7/22 19:21
rklessdriver Re: Engine cradle for an LT1
BrianCunningham wrote:
here's what I was looking at
http://www.summitracing.com/parts/SUM-910057
I have the same one and it fits LTX fine. Actually pretty decent piece for how little it cost.
Posted on: 2015/7/23 12:33
wow, what a deal!
Posted on: 2015/7/23 16:25
Thanks, ordered one
Posted on: 2015/7/23 22:03
Matatk Re: Engine cradle for an LT1
I had that for my L98. Decent stand. Two tips: 1) don't overtighten the bolts, they will break. 2) leave it a little loose when assembling it, then lower the motor and attach it, and then tighten it. Otherwise the holes won't line up with the block.
Posted on: 2015/7/24 12:50
Thanks for the assembly tips.
The Summit one came yesterday, that was quick.
I'll find out next week when I pick up the old engine.
Posted on: 2015/7/25 17:38
hcbph Re: Engine cradle for an LT1
269 Posts
wow, what a deal!
For that kind of $$ you can't make one, the metal required costs more than that.
Posted on: 2015/7/28 10:21
