240 user(s) are online (187 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
BrianCunningham Engine cradle for an LT1
Ordering up an engine cradle to store my old engine
Site says one for a small block wouldn't fit an LT1/4 engine
Includes standard wheels and Grade 5 fasteners. Will not fit early blocks without side motor mounts. Does not fit LT1 engines.
That true? New one on me.
Is so, what are you using?
Posted on: 2015/7/22 17:38
bogus Re: Engine cradle for an LT1
it will... they are idiots.
all you need are a cheap set of old style motor mounts, not the new rubber cylinder things we have.
The block bosses are the same.
About $4.00 each at Rockauto. I am assuming his cradle has the bracket on it to accept the mount.
The brand is DEA and the part # is A2713.
Posted on: 2015/7/22 18:19
BrianCunningham Re: Engine cradle for an LT1
Posted on: 2015/7/22 19:21
rklessdriver Re: Engine cradle for an LT1
BrianCunningham wrote:
here's what I was looking at
http://www.summitracing.com/parts/SUM-910057
I have the same one and it fits LTX fine. Actually pretty decent piece for how little it cost.
Posted on: 2015/7/23 12:33
wow, what a deal!
Posted on: 2015/7/23 16:25
Thanks, ordered one
Posted on: 2015/7/23 22:03
Matatk Re: Engine cradle for an LT1
I had that for my L98. Decent stand. Two tips: 1) don't overtighten the bolts, they will break. 2) leave it a little loose when assembling it, then lower the motor and attach it, and then tighten it. Otherwise the holes won't line up with the block.
Posted on: 2015/7/24 12:50
Thanks for the assembly tips.
The Summit one came yesterday, that was quick.
I'll find out next week when I pick up the old engine.
Posted on: 2015/7/25 17:38
hcbph Re: Engine cradle for an LT1
269 Posts
wow, what a deal!
For that kind of $$ you can't make one, the metal required costs more than that.
Posted on: 2015/7/28 10:21
