178 user(s) are online (152 user(s) are browsing Forums)
pianoguy Valve cover gaskets (LT4)
I was scouting around for oil leaks last night, and it looks like my valve covers are leaking toward the back, so I'm gonna replace the gaskets. Any particular brand or material better than the rest?
Thanks in advance!
Posted on: 2008/3/14 12:55
jhammons01 Re: Valve cover gaskets (LT4)
Good question, I just ordered the ~$17 pair from Kragen for my '84. I am not sure if they are good or not. I'll be able to report I guess in a month or so.
Posted on: 2008/3/14 13:32
BillH Re: Valve cover gaskets (LT4)
A lot of guys like the Felpro perma-dry, it's a silicon rubber gasket.
Sorry, I don't have the LT4 p/n but the LT1 is: VS50443R
You could find the part no. at Summit, "search by engine"
Posted on: 2008/3/14 15:13
pianoguy Re: Valve cover gaskets (LT4)
Thanks! Looks like NAPA carries them, too (pretty sure it's the same gasket for LT4).
Posted on: 2008/3/14 19:38
Valve cover gaskets......Silicone? Or Dry?
Posted on: 2008/3/14 22:19
Notorious Re: Valve cover gaskets (LT4)
Shouldn't need anything on a good silicone gasket. Also, some brands of gaskets for the later LTx composite covers come with new bolt grommets and some don't. But make sure and replace them too. They help to maintain the proper amount of pressure on the cover gasket. I remember that Carquest carried the grommets separately. Sometimes just replacing them will stop the leaking on the cover gasket.
Posted on: 2008/3/14 22:48
I hate sporks...
I'm pretty sure those Fel-Pro gaskets ($22.99 at NAPA) come with the grommets. I'll find out when I pick them up in the morning.
Posted on: 2008/3/15 1:37
