Slalom4me | 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
Can anyone recommend a source for a small capacity tank with an
internal pump suitable for EFI (40-60 psi)? I have looked at Jaz, RCI and ATL units but with the exception of the ATL Max-Sport, the others all appear to be externally pumped. I could use get by with a Jaz #250-003-05 tank and an MSD #2225 pump as shown below. But I would prefer the simpler, more sanitary in-tank combo. Price is a consideration and this takes units like the ATL Max-Sport out of the running. . |
Posted on: 2008/3/15 2:02
twisted | Re: 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
where are you going to mount it? is this for a c4?
Posted on: 2008/3/15 2:27
1986 Gold Z51 Coupe - MR 383, N2O and a wicked PeteK trans 1990 ZR-1 Artic White Grey Gut 37,247 miles For Sale twist... |
Slalom4me | Re: 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
Yes, it is for a C4. I have a couple of locations in mind.
Jaz also makes a 1 gal tank that is more compact. . |
Posted on: 2008/3/15 3:20
CasetheCorvetteman | Re: 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
How are ya slalom? I havent seen you in a while mate but ive been abit busy of late and havent been on here.
Why do you want such a small fuel tank? I have a couple of thoughts as to why you might, but im interested to know your reason mate. |
Posted on: 2008/3/15 5:45
BillH | Re: 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
Most of the smaller cells I've seen with internal pumps are custom in that they use a standard fill plate that's modified for the internal pump. Some are fairly simple mods using the 6 X 4 fill plate that has a 2 1/4 in. filler cap with 2 AN fittings in the plate (pressure & return). The fill plates I've seen have 1 inch or so of metal tubing below the plate (part of the 2 1/4 fill opening). The fuel pump is housed in a aluminum tube that is attached to the fill plate with a short rubber hose. The tube has cutouts at the bottom to allow more fuel to get to the pump. The pump wiring runs up thru the tube, thru a grommet in the tube and then thru a hole in the filler plate (with a grommet that has the wires epoxied to pervent leakage).
The aluminum tube and pump sit about a 1/4 inch above the bottom of the cell. I don't think you're going to find what you need as a standard item. The modification's not that hard to do if you can get the right fill plate and find the tubing. The pumps I've used are the ones from Wabro. |
Posted on: 2008/3/16 16:36
Thank you for the background & suggestions.
I have an L98-based in-tank assembly to adapt or serve as a model for a purpose-built unit, but the fabrication aspect confronts me with yet another time/money sink. The path of least resistance appears to be to settle for the external pump. . |
Posted on: 2008/3/18 3:52
CentralCoaster | Re: 3-5 Gal Tank w/ Internal Pump (40-100 psi) | ||
Settling is right.
Is there such a thing as an external pump that won't burn itself out? I don't think there's a single OEM that's used one, at least not by itself. It'll also be very noisy, probably not a concern for you though... Now, one pump that someone suggested to me for this type of application... is a mechanical piston type pump, where low suction pressure shouldn't phase it. Everything else is rotary-vane. http://www.shop.racepumps.com/product ... categoryId=1&productId=40 |
Posted on: 2008/3/18 17:02
Edited by CentralCoaster on 2008/3/18 17:19:21 |
Also I think an Airtex E8248 is probably the beefiest oem inline electric you can get.
Posted on: 2008/3/18 17:17
