brian | found 2 ZF 6 on ebay what do you guys think | ||
http://cgi.ebay.com/ebaymotors/89-96- ... 31QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/1989-9 ... 96QQrdZ1QQsspagenameZWDVW how can i tell that there is nothing wrong with the trannys over the internet? |
Posted on: 2008/3/14 17:09
ninetyfivevette | Re: found 2 ZF 6 on ebay what do you guys think | ||
Do you need just the trans or are you doing a conversion? Have you seen the NEW ZF6s on ebay for about $1400?
I bought mine to do my conversion from ebay, and it worked out fine. It's always a risk buying a used trans, especially when you're looking at units with 90K on them. |
Posted on: 2008/3/14 17:57
brian | Re: found 2 ZF 6 on ebay what do you guys think | ||
ive got a 1988 4+3 so if i got 6 speed i will need the conversion also. or if central coaster still has that 4 speed ill do that. i would like to do the 6 speed but it will get costly. so i prefer to do the 4 speed to save money and put that money saved into somthing else in the car cause i do have to do alot of work on the car.
Posted on: 2008/3/14 20:05
LD85 | Re: found 2 ZF 6 on ebay what do you guys think | ||
where do you live, my buddy has a Richmond 6 speed he might sell.
Posted on: 2008/3/14 22:04
2005/Z51 |
i live in sacramento CA. how much thou. cause i do have a bugdet.
Posted on: 2008/3/15 4:15
k guys i need some advice. what should i ask the sell about the transmission i asked him about the gears and miles on
http://cgi.ebay.com/ebaymotors/1989-9 ... 96QQrdZ1QQsspagenameZWDVW but what else should i ask him like syncros or get a picture of the gear box? |
Posted on: 2008/3/15 4:24
linky no worky
Posted on: 2008/3/15 13:39
2005/Z51 |
its the 2nd link in my first post
Posted on: 2008/3/15 14:19
How many miles does it have out of curiosity?
He says is shifts smooth, so if he's honest, that covers the syncros. You might make sure it's been kept up with the correct oil- ask him when was the last time it was changed and with what fluid. Also find out why it was pulled- accident? |
Posted on: 2008/3/16 0:07
i asked him miles on it and what year it was pulled from. once he responds ill ask him more
Posted on: 2008/3/16 0:09
CentralCoaster | Re: found 2 ZF 6 on ebay what do you guys think | ||
Hopefully it was pulled from a wrecked car, I can't think of any other reason it would be pulled and still good.
The seller can't/won't inspect the synchros for you, it's not easy like on the Super T10 (that I still need to check for you). Ask him what lube he used and when it was changed last. He has to drain it before shipping unless he has a cap for the rear seal. That first link is way overpriced. If you do get a used ZF, change the rear seal before you install it. These are very durable transmissions, they have a pretty low failure rate so I wouldn't worry too much about used if the owner can give you some good info. Only real weakness I've seen posted more than once is the overdrive gears can overheat if run at high speeds (~150mph) for too long and fail. |
Posted on: 2008/3/16 20:44
