221 user(s) are online (139 user(s) are browsing Forums)
90Vert Thermostat Change
Georgetown On.
29 Posts
Hi Guys I am going to change my thermostat to a 180 degree unit.
What is the easiest way to do this and what is the best way to drain and flush the cooling system and which is the best coolant to use ?
Thanks. Mark
Posted on: 2008/3/16 16:28
jsup Re: Thermostat Change
1778 Posts
Drain the radiator from the petcock on the bottom passenger side.
If you have an oil cooler, I'd take off the oil cooler hose on the block side and drain that too. It's low on the block and will drain the entire block.
Refill the block at the T-stat housing before you put the new T-stat in.
Fill the radiator from the tank up by the base of the windshield.
Done.
It's messy. I hate antifreeze, it's has such a horrible feel.
Posted on: 2008/3/16 18:46
90Vert Re: Thermostat Change
Georgetown On.
29 Posts
thanks for the info. I hope to get at it this week.
Posted on: 2008/3/17 12:19
twisted Re: Thermostat Change
New Jersey
20 Posts
to do a complete flush do as jsup said plus take the knock sensor out also to get that side of the bl;ock drained
Posted on: 2008/3/17 23:24
Notorious Re: Thermostat Change
Someone contact CFI-EFI and tell him there's a stat thread going on. I know he wouldn't want to miss it!
Posted on: 2008/3/18 2:12
