120 user(s) are online (73 user(s) are browsing Forums)
MikeB52 Doug Rippie Spring kit? Thoughts? Experience?
Massachusetts
61 Posts
Does anyone have or has anyone had the Doug Rippie coilover spring kit on their cars? I just picked up some 19 inch wheels (big I know, but I got a good deal). My concern is that the car will sit too high and look "donked out". Any southern folks out there will know what I mean. Anyway, I've been looking at coilover kits and this seems to be a decent kit without a astronomical price tag, at around 950 bucks. Anyone have anything for or against this kit?
Posted on: 2016/3/28 22:18
BillH Re: Doug Rippie Spring kit? Thoughts? Experience?
Doug is very............very well known in the racing community. Been doing Corvettes forever.
Since your main goal is chassis height (and not set up for hard track driving) a less expensive kit like this should work well for you.
Posted on: 2016/3/29 0:34
Matatk Re: Doug Rippie Spring kit? Thoughts? Experience?
If you're not sure, you can just try lowering the rear first. You can test it on the stock bolts, but they make a lowering kit through any of the vendors that is pretty inexpensive. That might be an avenue to check out.
Posted on: 2016/3/29 11:32
BrianCunningham Re: Doug Rippie Spring kit? Thoughts? Experience?
What is the tire diameter?
If you keep the tire diameter by using a lower profile tire, then you're not going to lower the car at all.
Posted on: 2016/3/29 15:37
MikeB52 Re: Doug Rippie Spring kit? Thoughts? Experience?
Massachusetts
61 Posts
I believe I'm still using a 35 in the rear and 40 in the front for profile on the tires. I live in new England and our roads suck. I was originally going to just try lowering the back with the bolts but I heard the handling is sacrificed as it takes the rake out of the car. 950 isn't bad, plus it'll be a coilover setup like I wanted in the first place. I don't race so I dont need anything too crazy. Just enough to have fun on the onramps with haha
Posted on: 2016/3/29 15:41
1994 Vette
Admiral Blue
6 speed
My post from the other coilover thread
BrianCunningham wrote:
Getting the original front spring out is the 1st hurtle
You need to raise the car up quite a bit since it curves quite a bit once unloaded.
The coilover goes on fairly easily
But depending on the diameter of the spring used, you may have to move the front swaybar.
Posted on: 2016/3/29 17:02
Massachusetts
61 Posts
Sounds legit to me. I'll order them up tonight! Thanks guys! Any advice on wheel bearings? Gonna do them while I'm in there. Are the moog ones junk?
Posted on: 2016/3/29 21:50
1994 Vette
Admiral Blue
6 speed
Sounds like the cheapos work so long as they're broken in.
Put some easy miles on the before having fun
Posted on: 2016/3/30 16:25
GOLDCYLON Re: Doug Rippie Spring kit? Thoughts? Experience?
Peoria, Arizona
23 Posts
The Timken bearings are pretty good and the DRM coil overs are an awesome mod
Posted on: 2016/7/10 4:18
GOLDCYLON - 91 ZR-1 #2014
Resized Image380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors,/R Baer Eradaspeed Rotors with Wilwood 6 piston front calipers
bogus Re: Doug Rippie Spring kit? Thoughts? Experience?
Check RockAuto.com for the wheel bearings.
Posted on: 2016/7/10 20:31
