234 user(s) are online (199 user(s) are browsing Forums)
BrianCunningham Car is running rich
Air-fuel gage is reading 7.8
Seeking advice on places to start looking
Vortech S-trim on a 1995 383 LT1 with AFR heads & a custom cam
Had the discharge pipe from the blower to the throttle body pop off a
couple of times
the flood of fuel lite off in the exhaust, flame out the exhaust
wondering if that fried the O2 sensors
thoughts?
Posted on: 2016/5/24 17:06
bogus Re: Car is running rich
flame out exhaust... that is always bad for an O2 sensor... Same for cats if they are still present.
Even if the flame isn't burning at the O2, the fuel is there, soaking the sensor.
I would start there.
Posted on: 2016/5/24 18:20
Matatk Re: Car is running rich
I agree.
And no obvious vacuum leaks?
Posted on: 2016/5/24 21:22
Woodstock Re: Car is running rich
Bremen/Germany
369 Posts
Maybe the temp sensor, indicating arctic temps?
Posted on: 2016/5/24 21:50
91 convertible
BrianCunningham Re: Car is running rich
found out while asking this question "over there" that Forced Induction & Scan & Tune have CLOSED
http://www.corvetteforum.com/forums/c ... trous-section-closed.html
Posted on: 2016/5/25 16:09
Interesting. I guess C4 owners ain't boosting anymore...
Posted on: 2016/5/25 19:42
Schrade Re: Car is running rich
O2 readings from Lt side vs Rt side???
Static FP tests with leakdown time?
Leaky INJ (excess fuel, NOT burning), will light up in HOT exhaust pipes, from 'lean' burn...
Posted on: 2016/5/30 1:11
Its from the gauge you see in my Avatar
Car is running fine, so I.m thinking its the gauge
Posted on: 2016/5/30 14:04
