BrianCunningham | Car is running rich | ||
Air-fuel gage is reading 7.8
Seeking advice on places to start looking Vortech S-trim on a 1995 383 LT1 with AFR heads & a custom cam Had the discharge pipe from the blower to the throttle body pop off a couple of times the flood of fuel lite off in the exhaust, flame out the exhaust wondering if that fried the O2 sensors thoughts? |
Posted on: 2016/5/24 17:06
bogus | Re: Car is running rich | ||
flame out exhaust... that is always bad for an O2 sensor... Same for cats if they are still present.
Even if the flame isn't burning at the O2, the fuel is there, soaking the sensor. I would start there. |
Posted on: 2016/5/24 18:20
Matatk | Re: Car is running rich | ||
I agree.
And no obvious vacuum leaks? |
Posted on: 2016/5/24 21:22
Woodstock | Re: Car is running rich | ||
Maybe the temp sensor, indicating arctic temps?
Posted on: 2016/5/24 21:50
91 convertible |
BrianCunningham | Re: Car is running rich | ||
found out while asking this question "over there" that Forced Induction & Scan & Tune have CLOSED
http://www.corvetteforum.com/forums/c ... trous-section-closed.html |
Posted on: 2016/5/25 16:09
Interesting. I guess C4 owners ain't boosting anymore...
Posted on: 2016/5/25 19:42
Schrade | Re: Car is running rich | ||
O2 readings from Lt side vs Rt side???
Static FP tests with leakdown time? Leaky INJ (excess fuel, NOT burning), will light up in HOT exhaust pipes, from 'lean' burn... |
Posted on: 2016/5/30 1:11
Its from the gauge you see in my Avatar
Car is running fine, so I.m thinking its the gauge |
Posted on: 2016/5/30 14:04
