261 user(s) are online (208 user(s) are browsing Forums)
BrianCunningham Wiper blades
Knowing it was going to rain at today's autocross,
I replaced my wiper blades
Turned them on and the passenger came up
That's great where's the other....
THOING!!!
What?!!!
Turns out the ones with those stupid adapter
DON'T CLEAR THE HOOD
Anyone know of any that clear
and where can I can them
Thanks in advance.
Posted on: 2016/6/5 19:00
joeld Re: Wiper blades
These are a real pain to find! For years I used the Trico Exact Fit, but they have changed the design on them and they hang up also.
Last set I put on my 89 came from the dealer #12363800 for approx 20 bucks. Worked good. But these are discontinued now!!
Not sure if the part number will cross over, haven't tried yet.
Try #12533416 GM parts.
I see the Delco # 8-2202 / 12533416 should fit.
Posted on: 2016/6/5 21:26
pianoguy Re: Wiper blades
The PIAA blades I bought several years ago work fine, but I don't have the details on them.
Posted on: 2016/6/6 0:26
hcbph Re: Wiper blades
269 Posts
Brian
Had the same type issue on my 86 plus had them come off when in use a couple of times. Tried 2 or 3 different brands then tried a set from NAPA (store labeled). Fit perfect and worked fine. I did do one thing added though, I put a small wire wrap around the arm and through the blade frame to insure it wouldn't come off like the others did, but I really don't think it was needed but reassuring to know they're on till I take them off.
I think I still have the package if you need the number, but just looked them up online.
Posted on: 2016/6/6 12:15
Matatk Re: Wiper blades
22808 Posts
The last set I put on were Trico 201. They clear fine on the 89.
Posted on: 2016/6/6 12:32
BrianCunningham Re: Wiper blades
do the earlier cars have different arms?
Tred a Trico 20-2 and the hole was to small
Posted on: 2016/6/7 0:20
bogus Re: Wiper blades
I don't have that problem... but, if you use any of the old school thin blades, without the big black thingy on them, you should be ok.
Posted on: 2016/6/7 1:46
22808 Posts
If you look at the blade post mount there are two different sized holes. You just have to remove the mount and flip it around.
Posted on: 2016/6/7 2:31
Ah-ya
bsstaats;
1984-1994: Trico 20-2 or 19-2
1995-1996: Trico 20-4
Posted on: 2016/6/7 2:36
22808 Posts
Guess you found it! 😃
Posted on: 2016/6/7 2:41
The ones the sold me today had the two holes you are talking about.
All set, thanks!
Posted on: 2016/6/7 18:15
