642 user(s) are online (175 user(s) are browsing Forums)
BrianCunningham So much for going drag racing tomorrow
Pulling out onto the main road from the house,
the Corvette through all the belts!
Need to pull it apart, install new belts and see what the damage is
So much for he Mustang vs Corvette drag race tomorrow
At least it happened at home and not going down the dragstrip!
Posted on: 2016/6/11 0:38
hcbph Re: So much for going drag racing tomorrow
269 Posts
Threw the belt(s)? Did they just come off or tear up?
Posted on: 2016/6/11 2:22
Matatk Re: So much for going drag racing tomorrow
22996 Posts
Did you look at it yet? Did something lock up?
Posted on: 2016/6/11 3:03
BrianCunningham Re: So much for going drag racing tomorrow
Tore up the blower belt which took out the stock belt
at least that's what I think
Posted on: 2016/6/11 16:01
269 Posts
Didn't realize there was a blower involved or multiple belts. Not knowing any part of it, assuming that nothing failed in the blower or possible tensioner, I'd look at either pulley alignment or belt failure first. I suppose it's possible to have pulley wobble but I'd look into alignment.
This all assuming you have not done whatever you did this time. If so then I'd look into belt failure first.
Posted on: 2016/6/12 1:03
22996 Posts
Looking forward to an update. In my experience, belts don't just shred for no reason. Hope it's something minor.
Posted on: 2016/6/12 3:17
Needed to order the custom blower belt
Has to come from the factory
Won't be here till the 22'd
Posted on: 2016/6/12 21:42
383tpimachine Re: So much for going drag racing tomorrow
Corpus Christi
976 Posts
What belt do you run?
Posted on: 2016/6/13 0:07
1970 El Camino-Awaiting LSX
K080525
Posted on: 2016/6/13 1:48
seems are friends @ RockAuto had one
should be here Wednesday
Posted on: 2016/6/13 14:16
Corpus Christi
976 Posts
Do they not make an HD version in that size?
Green belt is stiff as hell.
Posted on: 2016/6/14 1:40
Don't know
How do you cross reference the # to a green belt?
Posted on: 2016/6/14 16:13
Schrade Re: So much for going drag racing tomorrow
Can ALWAYS be a 'worse time' for the weak link to break...
No hardware damage?
Posted on: 2016/6/14 17:09
still inspecting
to be honest, I'm still cleaning out the "workspace"
Posted on: 2016/6/14 19:26
Started tearing it down
Mystery solved
There's a big chunk out of one of the pulleys!
Going to see if I can get a billet replacement
Posted on: 2016/6/14 23:16
Ordered a replacement pulley in metal
Posted on: 2016/6/15 17:07
Corpus Christi
976 Posts
BrianCunningham wrote:
Don't know
http://navigates.gates.com/AddedValue.aspx?PartNumber=K080525HD
Literally just adding HD to the end for your size.
Mine is stiff as hell but I may need to go down 1/2" for a tighter wrap.
Rockauto had mine in 94.5" in stock and they had a nice price as well.
Maybe order one and keep the regular as a spare?
Posted on: 2016/6/15 17:57
Don't know
thanks, same price too
Hopefully upgrading the pulley will take car of it
Posted on: 2016/6/15 18:36
after doing some additional teardown looks like it's damage as well
Not sure what happened but there's an 1/8in groove warn into the metal!
jpg  Pulley_damage.jpg (824.04 KB)
921_5763307dd05af.jpg 1840X3264 px
Posted on: 2016/6/16 23:04
22996 Posts
Time to find out what caused that. What is it rubbing? Hard to see from the photos.
Posted on: 2016/6/17 1:54
Another mystery solved:
Took another look
Why is there aluminum powder on my FRAME RAIL?
Yup, I'm twisting the engine enough to make the pulley GRIND THE FRAME!
Posted on: 2016/6/17 14:41
22996 Posts
Poly or solid motor mounts...get ready to vibrate your fillings out.
Posted on: 2016/6/17 15:04
Corpus Christi
976 Posts
Now that is pretty wild.
Do they even make solid mounts for the C4? I have the XE poly mounts but this has me thinking.
Posted on: 2016/6/17 15:51
Not that I know of
I thinking on installing a turnbuckle
Just talked with Greg@BlowerWorks
He can get me a smaller pulley
It's an idler so it won't mess up the drive ratio
Posted on: 2016/6/17 19:21
22996 Posts
Someone on CF had made solid motor mounts. I don't know of a commercial outlet for them.
Posted on: 2016/6/17 20:37
22996 Posts
Sounds like a better solution.
Posted on: 2016/6/17 20:38
bogus Re: So much for going drag racing tomorrow
The LT1 has a different mount system... this rubber thing full of something to make it hydraulic. I can see it giving up.
I don't know if traditional mounts would even work on the later C4.
I am sure something could be machined from poly and a bolt threaded through.
Posted on: 2016/6/18 3:40
I can't get a wrench on the 12 point bolt holding the bracket on.
This is a pic from the manual
On mine the blower pulley is still installed
jpg  12_point_bolt_vortech.jpg (651.38 KB)
921_57671b785f448.jpg 1200X900 px
Posted on: 2016/6/19 22:23
Workspace - that's one reason I WAS considering selling the Z - had to clear space for new projects, before starting...
But now that an INJ is leaking (in addition to oil catch can work), it has returned to the 'project table'.
still inspecting
Posted on: 2016/6/21 15:09
I finally got that stupid bolt out!
There's suppose to be a 12pt bolt so you can access it
But the second hand kit did not come with the hardware,
So my builder put a 6pt in instead
Finally got it off with a 9/16 socket on a 1/4in drive
Posted on: 2016/6/21 17:56
Pic of the damage with the bracket out.
Posted on: 2016/6/21 20:57
Talked to my builder yesterday, really just to ask how he managed to put it together :lol:
I mentioned the torque strap
He said not to use a chain or a turnbuckle.
They might set off the knock sensor
But a strap should work
Posted on: 2016/6/21 21:50
j3studio Re: So much for going drag racing tomorrow
Dear lord ...
Posted on: 2016/6/21 23:23
22996 Posts
What size is the 12 pt supposed to be, I can look in my bins for an extra.
Posted on: 2016/6/22 11:46
thanks
3/8-16 x 4.5” 12 point head bolt
fastenal has them for $7
but $54 to ship it overnight!
https://www.fastenal.com/products/details/0161200
Posted on: 2016/6/22 15:18
I made my living owning a Courier & Delivery - pretty well too...
$54 doesn't surprise me.
thanks
Posted on: 2016/6/22 16:02
Pic of the new pulleys next to the old ones
this shows the size difference
This won't effect the drive ratio
All rebuilt, I later put in on the blower & started to hook everything back up
Posted on: 2016/6/22 23:03
Just about have it all back together
Just need to hook up the radiator
BTW putting the belt back on is WAY easier with the radiator hoses out of the way.
I'll have 30 hours into it by the time I'm finished.
If I had gone back to the $75/hr shop that installed it that would have been $2,250
Posted on: 2016/6/23 22:27
22996 Posts
Good job!
Posted on: 2016/6/24 1:28
Son of a ...
The new idler is hitting the blower.
Didn't see it till I got it all together.
Need to tear it all apart AGAIN
Posted on: 2016/6/24 20:17
Something said for practice and knowing how it all comes apart.
I got it all apart in less that 3 hrs.
Summit sent me a stock plastic replacement
Need to helicoil one of the tapped holes in the bracket
Been together & apart too many times
NAPA had the correct helicoil kit in stock.
Posted on: 2016/6/27 22:35
Corpus Christi
976 Posts
These kits are close but are not perfect. I took an entire pulley off and clearanced a spacer as it was hitting.
Good you saw it before fireup causing damage.
Posted on: 2016/6/29 0:30
'Knowing' your motor; just what I preach.
Most would rather just drive 'em broken...
Posted on: 2016/7/2 18:35
The proper bolts came in today
Should be a lot easier putting it back together now
Posted on: 2016/7/6 0:45
??? Where is she now there?
It's a pain doin' vids, pics, write-up...........
Posted on: 2016/7/7 12:28
trying to find a puller for the non-stock one piece harmonic damper
Posted on: 2016/7/7 17:15
OK _finally_ had time to get the blower back on the car.
With the new _smaller_ idler pulley the belt K080525 seems a little _loose_
I had the next size down K080514, but that's way to short.
Tried looking up some different manufacturers, but can seem to find any in between the two
Posted on: 2016/7/26 23:12
IT'S ALIVE!
No belts in between those two sizes.
So I put it back together with the belt size I was running.
I'll see how much slip I get.
May not be that much, seeing I'm only running 5psi boost.
Letting it sit overnight to check to leaks.
I'll take it for a run tomorrow.
Posted on: 2016/7/27 22:05
Warmed up mill takes up a little belt tension???
IT'S ALIVE!
Posted on: 2016/7/28 12:05
Haven't heard that one before
Posted on: 2016/7/28 16:01
