474 user(s) are online (230 user(s) are browsing Forums)
BillH 67 Steering Column
Pics:
1. Shows all the parts, the column, hub and turn signal switch housing were glass beaded then painted factory (2 different colors of black.
2. The lower bearing - goofy stepped design, only used on the first 9,000 or so cars. The 2 bearings were $95 but those and one C-clip were all I had to buy. The plastic turn signal components were in extremely good condition.
3 & 4, A pile of those blue wire splices that bubba had used to crap up the harness (didn't know how to run the wires correctly). Soldered & heat shrinked.
5. Lower bearing & retainers.
6. Finished
jpg  IMG_1083.JPG (608.70 KB)
881_57f189b6db00c.jpg 1600X1200 px
jpg  IMG_1402.JPG (416.28 KB)
881_57f189c5e018b.jpg 1600X1200 px
jpg  IMG_1403.JPG (652.33 KB)
881_57f189dc09b0e.jpg 1600X1200 px
jpg  IMG_1404.JPG (577.08 KB)
881_57f189ea2dc72.jpg 1600X1200 px
jpg  IMG_1405.JPG (877.15 KB)
881_57f18a04e01dc.jpg 1600X1200 px
Posted on: 2016/10/2 22:28
BillH Re: 67 Steering Column
jpg  IMG_1408.JPG (535.70 KB)
881_57f18a26d64a1.jpg 1600X1200 px
jpg  IMG_1407.JPG (501.43 KB)
881_57f18a324c8e2.jpg 1600X1200 px
jpg  IMG_1409.JPG (582.81 KB)
881_57f18a3c5bdcc.jpg 1600X1200 px
Posted on: 2016/10/2 22:29
Ultraman Re: 67 Steering Column
15710 Posts
nice.....so is it time to install it in the car? hope so......boggles the mind when you think of all the small pieces that must function together to make the whole thing work........and these were relatively simple cars compared to the new ones.......
Posted on: 2016/10/2 22:33
Ultraman wrote:
nice.....so is it time to install it in the car? .
Unfortunately, no.
There's a boatload to do first.
I'm having a real problem deciding what to do with the wiper motor, it's a cosmetic restoration and to do the cad plating the motor brushes plate has to come out, it's in there with small copper revits and I can't source them.
But the resto costs $275.
The wiper motor has to go in before the heater box, almost impossible to get the wiper bolts in with the heater there.
Then, the radio speaker goes in, then the heater then the instrument panel and only then the steering column.
And that's after I find the damn missing steering column support bracket.
Posted on: 2016/10/2 22:42
joeld Re: 67 Steering Column
Good job on the build-up! Is that the original strg wheel? It looks new in the picture, sooo nice.
Posted on: 2016/10/2 23:21
Thanks Joel,
Yea, it's the original, in mint condition. The cleanup on it was less than 10 minutes.
Wish it was a teak wheel but those are going for $1,000 in so-so condition.
Posted on: 2016/10/3 0:08
pianoguy Re: 67 Steering Column
Looks like new, Bill!
Posted on: 2016/10/3 0:55
15710 Posts
That missing bracket is under the guest room bed.........in a box with some other stuff...........I may have had a vision.......I don't know.......
Posted on: 2016/10/3 3:55
teebee Re: 67 Steering Column
12849 Posts
Looks great Bill!
Posted on: 2016/10/3 3:58
