125 user(s) are online (93 user(s) are browsing Forums)
j3studio [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
How hard is to remove and replace the fuel injectors on an L98? I'm thinking of getting mine flowtested and cleaned by Rich at Cruzin Performance ...
Posted on: 2008/3/29 20:33
Chucks88 Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
Connectivette
12 Posts
Nice little project for you to do on the 'Vette. You'll learn quite a bit. No....not hard...just label everything. And you can't go wrong with R. Jensen either
Posted on: 2008/3/29 20:48
383/SR/219/AFR 190's 2800 vigilanti
CentralCoaster Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
Pretty easy, just a little time consuming your first go around.
If you run into any hangups gimme a ring, just not before noon your time 619-520-8685.
Getting the runners off and working with that stupid cold-start line can be tricky.
I would highly recommend using Rich for injectors, they'll come back looking like new and even if that wasn't the culprit, it's good preventative maintenance.
Posted on: 2008/3/29 20:58
j3studio Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
Thanks, guys!
:wave:
Posted on: 2008/3/29 21:07
bogus Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
yea, nice project for a weekend.
One set of Torx sockets and a 10mm socket. Not too bad at all.
Be ready to get new gaskets for the TPI.
Posted on: 2008/3/29 21:09
Thanks, Andy - are you talking about the intake manifold gaskets or the throttle body caskets or both or something else? Questions, questions, questions ...
Posted on: 2008/3/29 21:21
The intake runner gaskets. You will have to remove all of the plenum to get to the injector rails.
Also, has the intake base been re-gasketed? If not, I would consider it.
Posted on: 2008/3/30 1:24
Yeah the upper gaskets are dry and normally reusable, but if this is the first time you've pulled em, they'll probably come apart.
Posted on: 2008/3/30 7:41
volzfan Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
Kingsport, TN
306 Posts
It's not hard at all, just takes some time and patience. As for Cruzin.........I highly recommend him! I sent mine to Rich, had them back in a week, and couldn't be happier! I wouldn't hesitate to send more to him, when I need to. :thumbright:
Posted on: 2008/3/30 13:06
Vettes of the Smokies
Livin_the_dream Re: [Wow, J3Studio Is Really Starting To Work On The 85] How Hard Is It To R&R Injectors?
robesonia , pa
516 Posts
http://webpages.charter.net/buddiel/Injector%20Removal%20(WO%20Runner%20Removal)%201-04.doc
John this is a link to a procedure to remove your injectors. I used this when I did mine. I bought what they call an UPPER gasket set which was for the plenum and runners
Ok I cannot get the link to work by clicking on it. Copy the whole link and paste it in the address bar and it will work. Anyone know why it will not work correctly from here
Posted on: 2008/3/30 13:41
It's because the forum software doesn't translate the %20 to a space correctly - thanks for the link!
Posted on: 2008/3/30 16:26
John -
Photograph the process! Then we can create a Tech Tip here for it.
Posted on: 2008/3/30 19:27
John -
Andy,
I'd be happy to, though it's kind of scary that you would consider doing a tech tip from my car ...
Posted on: 2008/3/30 19:52
yea, well... your car is perfect, you can take pictures and I can fill it up with words that sound right.
seems like a great fit.
Posted on: 2008/3/30 19:54
We should do like Haynes does and disassemble his entire pristine car and reassemble it. Then we'd have all sorts of tech tips, and in 7 years, j3studio would be back on the road like it never even happened. And all he's gotta do is cover our beer tab.
Posted on: 2008/3/31 23:47
