xccter | Headlamp Door Popped off Housing! Ugly | ||
When I turned off my headlamps on the '88 last night I heard a clunk.
I found the headlamp cover sitting under the clamshell, undamaged. Lucky it didn't fly off at some earlier point I guess. Anyone know what type of adhesive is useded on these things? [IMG]http://i260.photobucket.com/albums/ii12/xccter/HeadlampDoor.jpg[/IMG] |
Posted on: 2008/3/29 14:40
´71 350/270 L48 Coupe Numbers Matching Ontario Orange 4 spd, Mid-year side pipes, deluxe black leather, ac, ps, pb, pw, tilt/tele steering wheel. 93k miles. Original rotors still riveted to the hubs! NCRS #48337 |
Mekanic | Re: Headlamp Door Popped off Housing! Ugly | ||
wow, this is a first as far as I know.
I would assume 3M double sided would be the adhesive of choice. I know thats what GM used for mounting the GS Flares, and several other things, so it only makes sense they would use it there too. |
Posted on: 2008/3/29 15:43
xccter | Re: Headlamp Door Popped off Housing! Ugly | ||
As luck would have it...
I'm having the new Targa painted on Monday, so I'll see what they have to re-attach it. Thanx |
Posted on: 2008/3/29 18:02
CentralCoaster | Re: Headlamp Door Popped off Housing! Ugly | ||
On my 85 it's glued to just 4 little pads, mine came partway off. Yours is a result of GM's redesign.
You need to use some super strong 2-part epoxy on there and to prep the surfaces well. Double stick isn't going to cut it. |
Posted on: 2008/3/29 19:47
bogus | Re: Headlamp Door Popped off Housing! Ugly | ||
Be sure the epoxy is able to deal with SMC.
Posted on: 2008/3/29 21:10
They seem to be some type of cheap pot metal, like the mirrors.
Posted on: 2008/3/29 22:54
I thought the lids were SMC? Interesting.
Hell, with pot metal, clean it up, and hit it with some JB Weld. |
Posted on: 2008/3/30 5:57
brian | Re: Headlamp Door Popped off Housing! Ugly | ||
my friends rx7 has a missing light cover it looks really funny.
Posted on: 2008/3/30 6:15
CasetheCorvetteman | Re: Headlamp Door Popped off Housing! Ugly | ||
Get yourself a Milwaukee V28 cordless hammer drill, drill a couple small pilot holes, then use some self drilling 3/4 inch tek screws. 3/4 inch should be long enough. Sounds like alot of overkill from the word go, but you dont want it to come off again
[IMG]http://i11.photobucket.com/albums/a185/Casethecorvetteman/Car%20work/Tools%20and%20equipment/V28PDX500.jpg[/IMG] |
Posted on: 2008/3/30 9:30
This is for sure not pot metal. SMC is my guess, and it's the same color as the body on both sides.
Posted on: 2008/3/30 20:36
