Ramrod | C-4 Tech Needed, 40 Codes | ||
1996 LT-1 can't pass smog certification, 2 "H" codes on the dash and 40 codes on my Zurich ZR 13 reader??? Any reputable C-4 techs in the 91763??
Posted on: 2021/5/13 20:18
1996 LT-1 DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc. |
Matatk | Re: C-4 Tech Needed, 40 Codes | ||
40 codes seems excessive. What are they? Could be an issue with the code reader. Was the battery dead recently? I'd clear the codes and see what comes back.
Posted on: 2021/5/14 0:21
bogus | Re: C-4 Tech Needed, 40 Codes | ||
40 codes would imply a bad PCM... if it was true.
Reset and retest... and if you can, list the codes. The codes themselves are the value, not a vague "I have codes, what do they mean" comment. |
Posted on: 2021/5/14 14:41
Ramrod | Re: C-4 Tech Needed, 40 Codes | ||
Zurich ZR-13 reader Chevrolet OEM Enhanced, 40 DTC
P0100-(1/40) https://www.dmv.de.gov/VehicleServices ... ections/pdfs/dtc_list.pdf The 1-40 codes are listed on my reader, most conflict with another, high voltage vs low voltage, high temp vs low temp etc. I suspected a bad PCM or a bad ground? Long story longer I took it to a reputable mechanic in Claremont, Ca for smog certification, they recommended new injectors I said OK. About 4 days and $$$$ they can't figure it out and suggest I throw more parts at it to fix and still no smog certification. |
Posted on: 2021/5/15 19:04
well.... stop spending money.
1. test the alternator 2. what injectors did you get? 3. check grounds - the battery ground to chassis will corrode 4. check battery terminals 5. test the battery |
Posted on: 2021/5/16 15:48
oh, how many miles?
Posted on: 2021/5/16 15:53
Ill give it a shot, im heading out for a few days and get on it then. Thanks for the suggestions.
Posted on: 2021/5/16 18:19
one hundred and twenty thousand
Posted on: 2021/5/16 18:21
120k... check grounds around the battery.
These cannot be "real" codes, if so, the engine would run like absolute garbage. |
Posted on: 2021/5/22 16:01
