118 user(s) are online (86 user(s) are browsing Forums)
1st Gear: 2.48
2nd Gear: 1.48
- 13 Bolt ...
pappyfreebird what a fuggan blast
1028 Posts
simple minded fuggar heyhuh !!!cause alls i did was drive it 50 miles!!!! but shes like gitton the lil womin ready ,,n short time later ,,i are a happy hippy....seems i tinker mo then drive ,,,but new ta me n wnat it all werkin cause besides choppers shell be a daily driver...well ifn i kin learn ta git in n out of the fuggan thing...needs a good rub down...any opinions on what ta use??? i have 3m fine rubbing compound werks great on bike tins (small stuff) ol grinder n buff wheels bout had it,,,so what be a good handjob wahahahah type stuff heyhuh??
Posted on: 2008/4/16 12:07
CSS996 Re: what a fuggan blast
Mega Guru
Central PA
3644 Posts
Congrabulashuns on the furst reel drive!
Yup, gettin' in 'n outs a beeyotch!
Hand job....
Posted on: 2008/4/16 14:22
Currently "Between Vettes".
JonnyAngle Re: what a fuggan blast
Minneapolis, MN
151 Posts
git yerself some fuggin hamberger grease frum Hormel. It'll be slicker /n snot. Or you can git yerself some wax from target thall match the color of yer paintjob. I use black colored wax on ma car cuz its black.
Posted on: 2008/4/16 16:39
pappyfreebird Re: what a fuggan blast
1028 Posts
yea i been lookin fer that there scratch n sniff stuff but no luck so far!!! figure ifn fug it up might as well smell purty>>.wahahahahahaha
Posted on: 2008/4/16 17:38
Touringmike Re: what a fuggan blast
Sussex,Wi
569 Posts
Sliker n sheit.
Too funny.
Posted on: 2008/4/17 11:29
ยด85 4+3
crash Re: what a fuggan blast
WRIGHT CITY MO 63390
977 Posts
IT TOOK AWHILE PAPPY BUT THEY COME AROUND TO YOUR WAY OF THINKING
RIDE ON BRO KEEP THE SHINY SIDE UP
Posted on: 2008/4/17 11:40
runner140 Re: what a fuggan blast
Ft. Lauderdale, Florida
721 Posts
Love the way you guy's write.
Posted on: 2008/4/17 11:57
1028 Posts
like ive said great bunch of rednecks in here...they chew me out now n then but werth the great tips...ive been thru lotsa lil things in this car...park brake light ,,,tranny oils,,,brakes r new,,,temp sensor n high pressure switch n freon(seems high pressure would blow my freon out) switch cured that,,,mirro switch,, well on its way,,,but been in there awready,,,wimpshield warsher pump should be in taday,,,again been in there awready too,,n tips from these cats made it easy,,,well still hadda a few swear werds but thats me in general i rekon,,,n she polished up real noice,,,all in all a good solid car so far,,,gonna be my beeyutch,,,fug awready like a womin ta me,,,3hrs afuggan round fer a 10 minute ride!!!! but its a fuggan ride thats fer sure!!! weeefuggaannhaaawww dudes,,,next saga of the illiterated derilected freebird will be the targa top,,,when its warm n dry,,,thanks fer puttin up wid me rednecks...ps wheres the tip on the door panel nawt stayin hooked up top,,,seems i have drivers side winder motor updated n passanger isnt(slow) but drivers door panel is loose at top....read bout lil L brackets prolly figure it out...but them pix n how toos are sure sweet.. ok i shut up n go back in my corner
Posted on: 2008/4/17 13:17
1028 Posts
ok outta my corner again (ok jus fer a minute k) did my raditor flush taday... pulled lower hose ,,,drained every thin out (purty red),,, then ran water thru her tell clean ,,,then hooked up lower n ran then pulled top n let her pass as thermo opend ,,,well you git the drift,,,also filled n syphund recovery jug,,,so noice fresh green shtuff in her now too...ony fluids aint new is dif. and clutch,,, time now fer some noice weather n vettin...she still idles to high to me.. shell go 1400 when fire it up cold here yet...then shell drop to 1000 n hot 8-9 ...800 ifn sit long nuff (like red light) ok back ta my corner...what are you manual tranny cats idlin at???
Posted on: 2008/4/17 23:57
polish41 Re: what a fuggan blast
Watertown.SD
50 Posts
I don't know about the manual tranny guys but my auto runs at 5 to 6 hundred at idle.
Posted on: 2008/4/18 2:55
If your not living life on the edge your taking up to much space.
1028 Posts
thanks dude,,,this mornin i watched it carefully,,,she starts up cold at 14-1500 n stays there till 180 degrees then drops off to 8-900...so that part seems proper...but ive seen seen em at (like yours )5-600,,,but clutches may be a tad higher,,,jus my thought but much lower n youed revin purty good ta git her rollin,,,hey oaklands n you other redneck manual tranny cats what say heyhuh,,,cc hows bout yer rig???
Posted on: 2008/4/18 12:03
1028 Posts
ps had the cat back put on yesterday too,,,dayum i dint realize a couple of tiny pinholes made her so loud,,,cause now i have a wussmoblie,,,shes awful quiet n really ony a few pinholes in each side,,, dang it,,,200 installed werent bad plus my lil jack thingie will now werk on dif.
Posted on: 2008/4/18 16:52
1028 Posts
well she got tested fer leaks yesterday... so safe ta say shes dry blowin down the freeway in heavy rain at 130....well ok maybe 60!!! fug 130 ida wet meself!!!! did have leak at the front top targa joint on both sides when sat ,,,strippins in purty good shape ,,,any tips
Posted on: 2008/4/19 16:23
