217 user(s) are online (162 user(s) are browsing Forums)
skirlin My antenna motor fell out...
Caledonia Michigan
277 Posts
My antenna motor fell out while backing up to leave for lunch. I had plans to pickup an antenna mast repair kit to replace the broke antenna...don't need it now. I was backing up and felt the thump as I rolled over something . There just happened to be a truck driver walking by and told me my motor just fell out, ripped out the wiring as well. He found it rather funny, I was torn between embarrassment and anger. With my FSM and the info on guru I will be ok. Luckily I usually listen to cd's. But it is almost 70 F out, the tops off, and it's all good.
Posted on: 2008/4/17 21:14
CentralCoaster Re: My antenna motor fell out...
I did the same, bottomed out on a bad road and it snapped the upper plastic nut off and fell out. It was at least hanging by the ground strap.
What year? I had such a hard time finding an exact replacement when the gears finally stripped out that I resorted to cannibalizing part of the old one to make it work.
Posted on: 2008/4/17 23:22
skirlin Re: My antenna motor fell out...
Caledonia Michigan
277 Posts
1992. I called Corvette Central but their computers are down and they couldn't help. I'll try again tomorrow morning, I was planning on a trip there tomorrow for shocks (Hmmm...bounce bounce). Hopefully it will be fixed. They didn't use the same one for all vette's?
Posted on: 2008/4/18 1:15
C4forlife Re: My antenna motor fell out...
Duncanville Texas
9 Posts
I got so tired of mine about two and a half years ago shaved the antenna hole. Connected it to a small straight antenna under the carpet.
Posted on: 2008/4/18 3:00
How's the reception? I was considering that too
Posted on: 2008/4/18 7:30
JonnyAngle Re: My antenna motor fell out...
Minneapolis, MN
151 Posts
I went to best buy and bought a new universal power antenna. Then i spliced in the antenna wire but never hooked up the power leads. It works great and is fabricated so it doesn't bounce around. I think it was $60. Buying OEM seems too spendy to me.
Posted on: 2008/4/18 18:06
pappyfreebird Re: My antenna motor fell out...
1028 Posts
mine is unhooked,,,but radio is fine in my parts ,,,lucky me i ain werried bout that fuggan ,,,dont think they should flip up n down evo time turn on tunes ,,,id make a remote somehow
Posted on: 2008/4/18 18:29
Duncanville Texas
9 Posts
Works a little bit better actually since you don't pick up inteference from the antenna moving the small amount it does in the wind. At one point i just made the cable function as the antenna by bending the inner part of the plug to touch the outer and even that worked well too.
Posted on: 2008/4/19 14:42
