279 user(s) are online (225 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
runner140 Ever happened to you......
Ft. Lauderdale, Florida
721 Posts
Driving home last night, on I595 at 70 mph (the speed limit)
and out of the corner of my eye I see a newspaper blowing all over the place. Its over three lanes away from my lane.
As we merge it goes exactly where you would guess it would go, right into my radiator.
All of a sudden, the temp gauge starts to climb...175--180--185 and 190. Got home and pulled out the first page of the Wall Street Journal, yesterdays edition.
I use a "Big Mouth Air Dam", guess its like a scoop sometimes. The big white vacuum cleaner at work.
Posted on: 2008/4/24 11:43
Matatk Re: Ever happened to you......
No newspapers, but I got a ton of leaves driving through the woods one day. I fabricated a screen and installed it - no more problems.
Posted on: 2008/4/24 15:32
toptechx6 Re: Ever happened to you......
south Florida
362 Posts
Just "bump draft" the guy ahead of you on the freeway like the Nascar guys do, low pressure should suck it right back out!
Posted on: 2008/4/24 15:40
runner140 Re: Ever happened to you......
721 Posts
Didn't Jeff Gordon do that several weeks ago?
Posted on: 2008/4/24 17:31
south Florida
362 Posts
If Jeffy did it then it was "reckless disregard for the safety of fellow competitors", if it was one of the Dodge guys then it would be, just racin'
Posted on: 2008/4/24 17:44
kentucky_vetter Re: Ever happened to you......
somerset, ky
154 Posts
That is exactly why I call my vette the "HOOVER". It sucks up everything on the road .
Posted on: 2008/4/24 21:22
JeepCycle Re: Ever happened to you......
Nesquehoning, PA...Pocono Mt.s
30 Posts
Whoa dude, you were 4 wheelin' your Vette...that takes some cajones man...what lift and tires do you use?
Posted on: 2008/4/27 14:54
TOO_HOTT Re: Ever happened to you......
25 Posts
Do you go to Tower shops?
Posted on: 2008/4/27 16:45
