207 user(s) are online (151 user(s) are browsing Forums)
GRIS, more...
PeteK new engine!
Not in the car yet, but I am building a new 406 for 2007. Block is being machined as I type.
I can't wait
Posted on: 2006/11/28 3:14
bogus RE:new engine!
whoa.
that's a lot of motor.
is the block a seasoned SBC or a new casting? Aluminum or factory iron?
What heads? Crank?
Posted on: 2006/12/3 4:02
PeteK RE:new engine!
I will be using a "vintage, seasoned" .030 block,
Scat cast crank, 5.7 rods and sealed power hyper pistons.
Cam is a custom ground comp hydraulic roller.
Compression will be about 10.9 to 1
Ran a similar combo in 05 but the block had an internal crack we did not find during the magnaflux process. I burnt the main bearing and blackened the crank on the dyno. Made decent power before it died though. I believe it was 445 hp and 490 ft lbs of torque. Should be a bit more fun than my current 383.
I do alot of projects for others, nice to have one going for myself. :thumbright:
Posted on: 2006/12/3 12:55
2 bolt or 4 bolt main?
sounds like some seriously honest power, but not so much as to make things tempermental.
EFI or carb?
Posted on: 2006/12/3 19:11
I am going to use the same parts that are on my 383.
Edelbrock ported heads
Hooker super comps w/true duals
Super ram
all will be switched.
Current combo runs 116.50 in the 1/4.
Hope to run 11.70 @118 after I figure everything out. Should be a fun project
:thumbright:
Posted on: 2006/12/3 22:16
red_johnny RE:new engine!
Sounds like a cool project. Good luck with it
Posted on: 2006/12/5 14:37
Block is completely machined and ready to be cleaned, painted and cam bearings installed. All will be done by me. Crank is in and scheduled to be balanced by tuesday. Pistons are likely fitted to the rods, or will be soon. Sounds like I will have everything a couple days before christmas..
I won't have an chance to do final assembly before february or march, but look forward to assembling it. It should rock and roll
I have to disassemble and go through my daughters NHRA Junior Dragster in order to be ready for opening day in march. Already have a few sponsors lined up for it. Things are coming together nicely for 07.
Posted on: 2006/12/17 22:41
freakd RE:new engine!
727 Posts
damn, sounds nice :thumbright:
keep us informed, i wanna see some #s
Posted on: 2006/12/17 22:45
I brought some stuff home yesterday. Blocks look fantastic when they are shotpeened. I oiled it down with wd-40 after bolting it up to the stand. I have alot on my plate currently and will not be able to assemble it for a few months.
Posted on: 2006/12/22 19:12
gee... get it all ready, then put the project on the back burner... unfair.
Posted on: 2006/12/30 6:36
It is killing me to shelf it, but I have to get caught up. I am currently plugging away. Next on the list is a c4 ford trans for a buddies 66 mustang.
Posted on: 2006/12/30 14:18
I pulled the trigger and ordered a brand new set of the AFR eliminator cylinder head. Now it may really rock and roll
Posted on: 2007/1/17 21:29
Awsome!!! I cant wait until I have the funds to play around with my set up
Posted on: 2007/1/18 1:49
727 Posts
waiting :tongue:
Posted on: 2007/1/18 8:17
EPiC RE:new engine!
13 Posts
Hey, Pete... was that a sb400 block?
Posted on: 2007/1/19 23:02
Yes it is. Factory 400 block with a .030 overbore. Special pistons with 350 connecting rod (5.700 length)
The factory 406 rods were 5.56. The 5.700 rods are easily available, cheap and result in a better rod/stroke ratio than the 5.65 rods.
Decent, inexpensive package that works well.
Posted on: 2007/1/20 3:19
EPiC RE:new engine!
13 Posts
I know of 2 guys that have built motors based on that 400 block. Sounds like you're gonna have a big cube torque monster when you're done!
Keep us informed!
Posted on: 2007/1/21 0:28
I may have a bigger project yet for 08. I have a friend that was going to build a 406 also. He has much more money in his block due to adding splayed 4 bolt main caps. I believe he has $1,300 invested. He has decided to bail out of it and wants to sell me the block, a set of $500 forged pop up pistons and a solid roller cam(both pistons and rods are brand new in the box) for $800.
I presume I can e-bay the pistons and cam to recoup $400 of the $800 spent. If it happens, I plan to begin aquiring a 3 7/8 stroke crank. The result will be a 420 cube monster. For the price, I have to buy it.
I have a couple of 383 stroker engines laying around. I may freshen those and sell them to fund the build up.
Posted on: 2007/1/21 17:13
If AFR delivers on time, I should have my new heads in 2-4 weeks. :thumbright:
I purchased the roller lifters last week.
The only things left to purchase is:
head gaskets
intake gaskets
header gaskets and collector gasket.
Not sure if I am going to drop it in after the snow melts, or if I should start and finish the LT 1 conversion and change up the whole package.
Decisions, decisions......
Posted on: 2007/2/26 13:44
Rocky RE:new engine!
Penn Valley, Ca.
4 Posts
Hey Pete, learn to post pictures so we can see the progress! :thumbright:
Posted on: 2007/3/1 1:53
84 Corvette under reconstruction. New crate motor, new to me Pete Kane 700r4 and TC. Detailing everything as I go.
Heads arrived yesterday. After a 13 week wait, I was happy to see the brown truck arrive. I was less than thrilled with the quality of the heads though
Posted on: 2007/4/8 1:10
a set of AFRs with questionable QC? Never happen.
Posted on: 2007/4/8 23:44
