bomar76 | 87 coupe automatic no start | ||
Read the recent post on the 84 no start issue, but the 87's seem different enough I need some direction...
Son's 87 automatic coupe... No prior starting trouble (other than battery was FUBARED at end of winter layup and replaced) New, good battery, fully charged. Good connections. All courtesy lights come on when door opened. Turn key (in Park) a few relays click, a/c clutch engages, no crank, no noise from starter. Put vette in Neutral, no different. Play w/ shifter in various gears ( suspecting Neutral Safety Switch), still no crank in Start. Tried different VATS keys suspecting a bad resistor, no difference. Need guidance.... Bad Neutral Safety Switch (which I am guessing is in console) Bad VATS? Bad ignition switch? Some other theft deterent system haywire? |
Posted on: 2008/5/3 17:59
1987 Coupe Automatic Electronic Climate Control |
bogus | Re: 87 coupe automatic no start | ||
What about the starter? It could have a bad bendix or failed solinoid.
As annoying as that would be... I would also be 100% sure the connections to the starter are good. For me, it doesn't sound like a VATS issue... at least not yet. When you turn the key, do the lights dim? If not, then it's VATS. |
Posted on: 2008/5/3 18:09
toptechx6 | Re: 87 coupe automatic no start | ||
Factory Service Manual, Electrical Diagnosis section, locate and follow the chart for a no crank condition.
Posted on: 2008/5/3 18:12
bomar76 | Re: 87 coupe automatic no start | ||
I have had my hand on starter when key is turned to Start and there is nothing felt...
Headlights do NOT dim when key is in Start. |
Posted on: 2008/5/3 18:17
I have a pdf file of the FSM....that is not searchable though links, just page by page.
Happen to have a page #? |
Posted on: 2008/5/3 18:18
gee... no pages in my head... I think it is book 2, tho.
It sounds like VATS... read this site. http://www.vatssucks.com/ It's very well done! |
Posted on: 2008/5/3 18:25
joeld | Re: 87 coupe automatic no start | ||
Can you hear the fuel pump prime for 2-3 seconds when you turn key on? If so, VATS is not the problem. Turn radio off and listen very carefully.
Joel Hold on, I'm thinking of the injector pulse not pump. I'll have to recheck on pump not running. Sorry Joel |
Posted on: 2008/5/3 20:14
Edited by joeld on 2008/5/3 21:40:30 |
1989 Coupe,L98 automatic |
Thanks for all the help so far....
I visited the site Bogus advised and went to Radio Shack to p/u some resistors to try th work around....I'll also go out and listen for the fuel pump just in case.... |
Posted on: 2008/5/4 0:33
LarryK87 | Re: 87 coupe automatic no start | ||
just as an off chance, the starters on the 87's are fairly easy to reach, try giving the starter a good solid rap with a hammer, the reason being the brush's may not be making contact ( but would think you would still hear the bendex engage ) if it then starts, new starter time ( they are cheap and common. The blow of the hammer will cause the brush's to set.
Posted on: 2008/5/4 10:59
Bogus, I cannot thank you enough for the vats sucks site....
I made up the resistor bundle per the directions, instaled it, and the Vette fired right off!!!! Man, I owe you 100 beers!!! Thanks Thanks Thanks !!!! |
Posted on: 2008/5/4 14:14
CasetheCorvetteman | Re: 87 coupe automatic no start | ||
That doesnt mean much Quote:
Glosary Quote:
Delco 10MT. Very easy to come by. 9 times out of 10, the brushes are worn down and the screws are transmitting the electrical charge to the amature. Used in the following: Low torque applications '63-'64 Ford Truck '59-'68 AMC '57-'63 Buick '57-'74 Cadillac '64-'80 Checker Cab '57-'74 Chevrolet '55-'78 Chevy and GMC Trucks '57-'79 International Trucks '61-'71 Jeep '57-'74 Oldsmobile '56-'74 Pontiac '65-'66 Studebaker Marine applications included '67-'78 Chris Craft '61-'75 Crusader '57-'67 Gray Marine '67-'78 Johnson-Evinrude '71-'78 Mercury Marine '55-'63 Palmer Marine '61-'64 Universal Marine Industrial and Farm applications such as Towmotor, Caterpillar, Case, John Deere, Waukesha and Massey-Ferguson. High torque versions of the 10MT: '64-'81 Buick '64-'84 Cadillac '75-'81 Chevrolet '73-'91 Chevrolet and GMC Trucks '64-'80 International Trucks '80-'83 AMC and Jeep '75-'81 Oldsmobile and Pontiac Quote:
I taught him all he knows, so ill have those beers thanks mate |
Posted on: 2008/5/4 15:03
Well, dunno what all that was about, but it's fixed even w/o all that extraneous info.
Posted on: 2008/5/4 15:17
Well as im noticing more and more these days, people dont seem to apreciate information presented to them, whether it helps or not.
Whether or not it seemed extraneous to you, if one day you were interested to know what vehicles came with a Delco 10MT starter motor, had i not posted, youd have had to look it up. Sure, youd have found the info, but not like as if i did you a dis service by telling you. Now i dont really know for sure, but just by the tone of your post, i dont get the feeling youre being too polite. In fact i get the impression youre telling me my assistance is not wanted in any way, shape, or form. So due to that theory i have, i think maybe if i dont offer any assistance, then i probably wont have to worry about people not apreciating it. Some people apreciate efforts made by others, some people dont. Some people can apreciate a bit of a joke, some people just cant. I think over the past few years ive given alot of my free time to people that dont apreciate it. Am i obliged to do so? Most certainly not. Did i put myself out to get you that info? You bet your arse i did. Why did i? Cause i thought you might like to know. So what do you reckon? |
Posted on: 2008/5/4 16:27
jeez children.
As for the lights not dimming. That is very important. Even a mildly screwed starter will draw SOME current. If the starter has been totally disconnected from the equation, as with a VATS issue, then guess what - ZERO DRAIN. The list is very useful. No question. It's always nice to know cross-references. |
Posted on: 2008/5/4 19:05
Matatk | Re: 87 coupe automatic no start | ||
Don't worry Case - I'll still buy you a beer!!! Matthew |
Posted on: 2008/5/5 13:22
Sounds good to me Matty
Posted on: 2008/5/5 13:27
You just have to come to Chicago to get it - it will be too warm if I airmail it
Matthew |
Posted on: 2008/5/5 13:32
Will be a while mate, ill go one day, but then i loose interest in things quite quickly you see.
If i can stay out of the tool shop long enough ill make it over for a beer |
Posted on: 2008/5/7 9:50
