251 user(s) are online (195 user(s) are browsing Forums)
bomar76 87 coupe automatic no start
Marysville Ohio
37 Posts
Read the recent post on the 84 no start issue, but the 87's seem different enough I need some direction...
Son's 87 automatic coupe...
No prior starting trouble (other than battery was FUBARED at end of winter layup and replaced)
New, good battery, fully charged.
Good connections.
All courtesy lights come on when door opened.
Turn key (in Park) a few relays click, a/c clutch engages, no crank, no noise from starter.
Put vette in Neutral, no different.
Play w/ shifter in various gears ( suspecting Neutral Safety Switch), still no crank in Start.
Tried different VATS keys suspecting a bad resistor, no difference.
Need guidance....
Bad Neutral Safety Switch (which I am guessing is in console)
Bad VATS?
Bad ignition switch?
Some other theft deterent system haywire?
Posted on: 2008/5/3 17:59
1987 Coupe
Automatic
Electronic Climate Control
bogus Re: 87 coupe automatic no start
What about the starter? It could have a bad bendix or failed solinoid.
As annoying as that would be...
I would also be 100% sure the connections to the starter are good.
For me, it doesn't sound like a VATS issue... at least not yet.
When you turn the key, do the lights dim? If not, then it's VATS.
Posted on: 2008/5/3 18:09
toptechx6 Re: 87 coupe automatic no start
south Florida
362 Posts
Factory Service Manual, Electrical Diagnosis section, locate and follow the chart for a no crank condition.
Posted on: 2008/5/3 18:12
bomar76 Re: 87 coupe automatic no start
Marysville Ohio
37 Posts
I have had my hand on starter when key is turned to Start and there is nothing felt...
Headlights do NOT dim when key is in Start.
Posted on: 2008/5/3 18:17
1987 Coupe
Automatic
Marysville Ohio
37 Posts
I have a pdf file of the FSM....that is not searchable though links, just page by page.
Happen to have a page #?
Posted on: 2008/5/3 18:18
1987 Coupe
Automatic
gee... no pages in my head... I think it is book 2, tho.
It sounds like VATS... read this site.
http://www.vatssucks.com/
It's very well done!
Posted on: 2008/5/3 18:25
joeld Re: 87 coupe automatic no start
Can you hear the fuel pump prime for 2-3 seconds when you turn key on? If so, VATS is not the problem. Turn radio off and listen very carefully.
Hold on, I'm thinking of the injector pulse not pump. I'll have to recheck on pump not running. Sorry
Posted on: 2008/5/3 20:14
Edited by joeld on 2008/5/3 21:40:30
Marysville Ohio
37 Posts
Thanks for all the help so far....
I visited the site Bogus advised and went to Radio Shack to p/u some resistors to try th work around....I'll also go out and listen for the fuel pump just in case....
Posted on: 2008/5/4 0:33
1987 Coupe
Automatic
LarryK87 Re: 87 coupe automatic no start
Port Charlotte, Fl
10 Posts
just as an off chance, the starters on the 87's are fairly easy to reach, try giving the starter a good solid rap with a hammer, the reason being the brush's may not be making contact ( but would think you would still hear the bendex engage ) if it then starts, new starter time ( they are cheap and common. The blow of the hammer will cause the brush's to set.
Posted on: 2008/5/4 10:59
Marysville Ohio
37 Posts
Bogus, I cannot thank you enough for the vats sucks site....
I made up the resistor bundle per the directions, instaled it, and the Vette fired right off!!!!
Man, I owe you 100 beers!!!
Thanks Thanks Thanks !!!!
Posted on: 2008/5/4 14:14
1987 Coupe
Automatic
CasetheCorvetteman Re: 87 coupe automatic no start
That doesnt mean much
Glosary
Delco 10MT. Very easy to come by. 9 times out of 10, the brushes are worn down and the screws are transmitting the electrical charge to the amature.
Used in the following:
Low torque applications
'63-'64 Ford Truck
'59-'68 AMC
'57-'63 Buick
'57-'74 Cadillac
'64-'80 Checker Cab
'57-'74 Chevrolet
'55-'78 Chevy and GMC Trucks
'57-'79 International Trucks
'61-'71 Jeep
'57-'74 Oldsmobile
'56-'74 Pontiac
'65-'66 Studebaker
Marine applications included
'67-'78 Chris Craft
'61-'75 Crusader
'57-'67 Gray Marine
'67-'78 Johnson-Evinrude
'71-'78 Mercury Marine
'55-'63 Palmer Marine
'61-'64 Universal Marine
Industrial and Farm applications such as Towmotor, Caterpillar, Case, John Deere, Waukesha and Massey-Ferguson.
High torque versions of the 10MT:
'64-'81 Buick
'64-'84 Cadillac
'75-'81 Chevrolet
'73-'91 Chevrolet and GMC Trucks
'64-'80 International Trucks
'80-'83 AMC and Jeep
'75-'81 Oldsmobile and Pontiac
I taught him all he knows, so ill have those beers thanks mate
Posted on: 2008/5/4 15:03
Marysville Ohio
37 Posts
Well, dunno what all that was about, but it's fixed even w/o all that extraneous info.
Posted on: 2008/5/4 15:17
1987 Coupe
Automatic
Well as im noticing more and more these days, people dont seem to apreciate information presented to them, whether it helps or not.
Whether or not it seemed extraneous to you, if one day you were interested to know what vehicles came with a Delco 10MT starter motor, had i not posted, youd have had to look it up. Sure, youd have found the info, but not like as if i did you a dis service by telling you.
Now i dont really know for sure, but just by the tone of your post, i dont get the feeling youre being too polite. In fact i get the impression youre telling me my assistance is not wanted in any way, shape, or form.
So due to that theory i have, i think maybe if i dont offer any assistance, then i probably wont have to worry about people not apreciating it.
Some people apreciate efforts made by others, some people dont. Some people can apreciate a bit of a joke, some people just cant.
I think over the past few years ive given alot of my free time to people that dont apreciate it. Am i obliged to do so? Most certainly not. Did i put myself out to get you that info? You bet your arse i did. Why did i? Cause i thought you might like to know.
So what do you reckon?
Posted on: 2008/5/4 16:27
jeez children.
As for the lights not dimming. That is very important. Even a mildly screwed starter will draw SOME current. If the starter has been totally disconnected from the equation, as with a VATS issue, then guess what - ZERO DRAIN.
The list is very useful. No question. It's always nice to know cross-references.
Posted on: 2008/5/4 19:05
Matatk Re: 87 coupe automatic no start
Don't worry Case - I'll still buy you a beer!!!
Posted on: 2008/5/5 13:22
Sounds good to me Matty
Posted on: 2008/5/5 13:27
You just have to come to Chicago to get it - it will be too warm if I airmail it
Posted on: 2008/5/5 13:32
Will be a while mate, ill go one day, but then i loose interest in things quite quickly you see.
If i can stay out of the tool shop long enough ill make it over for a beer
Posted on: 2008/5/7 9:50
