76 user(s) are online (40 user(s) are browsing Forums)
Antilock Braking System.
CentralCoaster L98 Throttle body bypass - stealth
I did this awhile ago and stumbled across this pic.
You can route the bypass hose underneath the a/c compressor. This does NOT require removing the a/c compressor, I just happened to have it out for other reasons.
I protected the hose because there's an edge on the a/c bracket towards the front of the intake and I didn't want it rubbing through.
Tight fit, but much better than hoses stretched across the engine.
I think I've got some pics with the compressor back installed too... Hmm...
Also later on I added some EZ-Coils from goodyear (springy looking things) just as peace of mind to prevent the hose from ever kinking.
Posted on: 2008/5/13 23:30
Edited by CentralCoaster on 2008/5/14 3:28:18
pianoguy Re: L98 Throttle body bypass - stealth
Either the 70's and 80's were even more fun than I can remember, or you forgot to post the pic.
Never mind, it magically appeared.
Posted on: 2008/5/13 23:33
Matatk Re: L98 Throttle body bypass - stealth
Hey central - can you put up some more pics or outline the steps, because I plan on doing it when I install the new rad.
Thanks,
Posted on: 2008/5/14 13:13
CentralCoaster Re: L98 Throttle body bypass - stealth
Steps?
1) Remove 2 factory TB hoses.
2) Shove 5/8" heater hose under a/c compressor, connect to front of TB and upper heater hose.
3) Tighten clamps.
Posted on: 2008/5/14 16:08
bogus Re: L98 Throttle body bypass - stealth
where did you get the cool blue hoses?
Posted on: 2008/5/15 3:03
JrRifleCoach Re: L98 Throttle body bypass - stealth
1524 Posts
www.coolbluehoses.com
Posted on: 2008/5/15 5:51
I didn't know if there was anything special - ie different length hoses, caps for the TB, connections, etc.
Thanks.
Posted on: 2008/5/15 13:10
Those are Goodyear HiMiler hoses. The kit with the rad hoses is about $50 then I had to buy some extra in bulk. Summit sells it in 6'(?) lengths. They claim it's more durable than silicone. I got sick of replacement hoses lasting a 2 years or so (considering the original hoses were on the car for 15+ years.)
You can also get clamps from them that have a protective piece to prevent the threads from digging into the hose.
I recall the heater lines are 3/4 and 5/8. I was able to change everything except for this stupid little section that feeds the oil cooler, the molded hose shrinks from 3/4 to 5/8" and connects to a steel tee.
Posted on: 2008/5/15 16:38
hulagan808 Re: L98 Throttle body bypass - stealth
hawaii, maui
58 Posts
So you have the kc-4 (I think)water/oil heat exchanger then?
Posted on: 2008/6/28 4:25
88 vert, gen 7, superram, blah blah blah for days
I dunno what KC4 is. This is the factory z51 cooler, pumps a little coolant through an adapter above the oil filter.
I think it's basically worthless. It does help warm the oil a little faster on a cold start, so that's useful.
I need to do something different for my oil temps before I do any more track days.
Welcome to the forum btw!
Posted on: 2008/6/28 4:38
Randyj75 Re: L98 Throttle body bypass - stealth
MD
129 Posts
You can't to that if you have an oil cooler, the union for the hose that runs down below the engine is located under the A/C compressor.
Looks good though. Love the blue hoses. Its a shame the don't make them for '90+ Corvettes.
Randy
Posted on: 2008/6/28 6:39
hawaii, maui
58 Posts
Thanks! yes it is kinda worthless IMO, with lots to go wrong as far as coolant goes. removed mine and went with a traditional cooler. kc4 is the factory code for this option. and it realy is a heat exchanger. best suited for fast warmup of oil. Aloha
Posted on: 2008/6/28 6:54
Yes you can. I have the factory oil cooler. The tee is sorta blocked by the bottom part of the ac bracket in the pic.
Posted on: 2008/6/29 0:55
