295 user(s) are online (235 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
joesroad Good Mechanic
central florida
16 Posts
Anyone here know of a good vette mechanic in the Ocala Florida area? So far they seem few and far away. Any sugestions will be welcome.
Posted on: 2007/2/9 1:26
freakd RE:Good Mechanic
727 Posts
is there a club down there??you could always ask there. pm justardneck, he might be able to hook you up as well :thumbright:
dana is a good guy
Posted on: 2007/2/10 14:23
joesroad RE:Good Mechanic
central florida
16 Posts
I have contacted the Marion County Corvette club here but have not got any response yet. Thanks for the tip for justardneck, I'll see if he can help.
Posted on: 2007/2/11 2:29
bogus RE:Good Mechanic
what kinda issues are you having?
Many issues on a C4 can be handled by a good general technician. In turn, it does not require you to spend huge dollars at a specialty shop.
Not all specialty shops are bad, but they do have a generally poor rep of burning people on the bill.
A woman over at CF got raped by a shop up in Illinois a few weeks back... she overpaid by at least 1000.00, because they double charged on labour.
Just be cautious.
Posted on: 2007/2/11 21:24
central florida
16 Posts
I have tried a few shops here that should have been able to find the cause but have not yet. The noise coming from the right rear sounds like a clunking and sqeaking noise but all ujoints seem fine. It happens more when I accelerate and sometimes not at all. One shop told me my transmission was bad. I would just like to be sure of what the problem is before pouring money in it.
Posted on: 2007/2/12 14:58
727 Posts
sounds to me like it might be bearings.
especially with the noise coming from the rear.
Posted on: 2007/2/12 20:10
90EXPVette RE:Good Mechanic
Martinez, Georgia
185 Posts
Mine made a similar sound before I replaced the bearings...it's not hard to check...get the Vette in the air and see if there is any play in the wheel (try to move it laterally) if there's any "slop" you've found the problem.
Posted on: 2007/2/13 13:56
central florida
16 Posts
Thanks for the tip, are they hard to change?
Posted on: 2007/2/13 16:59
727 Posts
kind of a pain in the ass, but worth it to do yourself, i did mine on the 87 last winter, with the help of bigjohn, well worth the effort :thumbright:
Posted on: 2007/2/13 19:43
727 Posts
i got my bearings from tld{the last detail} corvettes :tongue:
Posted on: 2007/2/13 19:44
yea, bearings are not too bad... just be sure to have a supply of T55 torx sockets... well, depending on vintage, that is.
Posted on: 2007/2/15 3:47
central florida
16 Posts
She is a 1988 with 80,000 on the clock. I,m going to tackle the bearings this weekend and will post results after. Thanks to all for the help. :thumbleft:
Posted on: 2007/2/15 10:46
central florida
16 Posts
Well got her fixed today, turn out once I got into it that the problem was the u-joints on the half shaft. Wheel bearing was still good. Changing out all the rest this weekend. Not that I am complaining because the u-joints are alot cheaper to replace. Thanks again for all the tips. :thumbright:
Posted on: 2007/2/16 1:16
cool! glad to hear all is well.
ujoints can make one think the bearing is failing. It's one of those things where it is perhaps a good idea to replace both the bearings and the ujoints at the same time. it does save on the labour a bit.
Posted on: 2007/2/19 23:10
CREWZIN RE:Good Mechanic
Lecanto, Florida
78 Posts
Glad you found the problem. I've been away for abit and just saw your post. If you don't mind driving a little ways, I can recommend an auto shop in Inverness. The owner and one of the mechanics own their own Vette and they do mechanical and restoration work. Myself and a few others from the Citrus County Corvette Club use this shop. The owners name is Cliff and shop is located on 44E heading towards Wildwood. I don't have the exact address but the number is (352) 344-1110 and called East Cove Auto Center.
Posted on: 2007/2/20 16:54
central florida
16 Posts
Thanks crewzin, alot of this stuff I can tackle myself but its always nice to know of a mechanic to fall back on. My dad lives near Inverness so I get out that way often. Thats a pretty nice drive from here about an hour. I'll have to stop in one day. :thumbright:
Posted on: 2007/2/20 23:41
