132 user(s) are online (99 user(s) are browsing Forums)
GRIS, more...
Danspeed1 What Causes Oil in the Intake???
Mooresville, North Carolina
1121 Posts
Thankfully, for once.... this is not my car. But the problem is driving me nuts because I feel like I should have a list of reasons why, but I am just stumped? Must have missed that day of class... or I was drunk??
2002 Ford Taurus...
Car has no power at all. Stalls at WOT. And at moves at a top speed of 20 MPH at 50% throttle. Makes the worst noises, and smells.
I did a vacuum check for the guy, and its got 22lbs of Vac. He replaced both Cats already... and the fuel filter.
Today we pulled off the intake tube leading to the throttle body only to find about 1/2 a quart of oil dripping out! WTF?
I know I learned about this but I just cant seem to remember.
DG
Posted on: 2008/6/10 1:38
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Matatk Re: What Causes Oil in the Intake???
Bad PCV valve.
Check out this post on a ford site I found from yahoo:
http://forums.corral.net/forums/showt ... ghlight=consumption+valve
That should solve your problems!
Posted on: 2008/6/10 1:48
Danspeed1 Re: What Causes Oil in the Intake???
1121 Posts
Read through it but I am still on the fence.
I thought about the PCV, and infact I pulled all the hoses and flushed them. I did not however pull the PCV because it is a PITA to get to and its not my car (thank god). But it is def. worth mentioning.
The only thing with the PCV that I am wondering. Would it really cause enough pressure to bog the engine to a stall on acceleration?
Another thing that I have been tossing over in my mind... I can't remember, but I think a clogged PCV would cause low manifold vacuum... not normal vacuum right? (maybe I am wrong)
DG
Posted on: 2008/6/10 2:18
1996 Ford Explorer
2009 Cadillac CTS-v
What is the vacuum pressure supposed to be?
Too much could draw oil in. Just a thought.
Posted on: 2008/6/10 2:30
CentralCoaster Re: What Causes Oil in the Intake???
PCV does draw oil residue into the intake, but there's also a pcv vent, and this overflows into the intake if there's too much blowby.
But neither should be filling the intake with oil quickly. Maybe the taurus has some garbage baffle in there or something.
Is there oil in either the pcv line or pcv vent line? A new pcv is about $3 so just replace it anyways.
Posted on: 2008/6/10 18:37
1121 Posts
We were playing with the car again today. I mentioned replacing the PCV and its a good thing we did. The other one was stuck and caked in sludge! So far everything we have replaced on speculation has been bad . The cat for example was missing substrate and was making a racket. But still the problem has not been fixed. The car still can't make it over 20MPH, and its sounds like a suffering cat (animal).
I think my next suggestion is going to be plugs. I don't see how plugs could force the car to barely run within just 100 miles of driving, but it seems like little or no maintenance has been done to the vehicle... so what the heck. (its not my money anywayz ) LOL j/k
DG
Posted on: 2008/6/11 4:42
1996 Ford Explorer
2009 Cadillac CTS-v
toptechx6 Re: What Causes Oil in the Intake???
south Florida
362 Posts
You didn't say what you did with the damaged cat, removed, replaced? Where did the broken substrate go? How about downstream and still plugging the exhaust?
Posted on: 2008/6/11 10:01
Mekanic Re: What Causes Oil in the Intake???
Tampa Bay Florida
827 Posts
plugged exhaust, cam timing, ignition timing advance, or a shot engine.
Those are what would cause the issue it is having.
Posted on: 2008/6/11 10:44
~Rich
Polo LT4
Mekanic wrote:
....or a shot engine.
That's the best diagnosis yet!
Posted on: 2008/6/12 4:01
1121 Posts
I think shot engine is where we are going to stand.... .
Ill find out more tomorrow!
DG
Posted on: 2008/6/12 4:34
1996 Ford Explorer
2009 Cadillac CTS-v
Have you done a compression or leakdown test? My LTD has two dead cylinders and doesn't blow oil into the intake.
Could be bent rods though on mine.
Posted on: 2008/6/12 15:04
1121 Posts
Ding.... Ding.... Ding....
And the winners are
TopTechX6 & Mekanic
Plugged exhaust it is.....
DG
Posted on: 2008/6/14 21:51
1996 Ford Explorer
2009 Cadillac CTS-v
