280 user(s) are online (238 user(s) are browsing Forums)
Matatk Air pump gone...
Well, I wanted to get rid of my air pump because it is so cumbersome in the engine bay and I wanted to clean it up a little. I looked into the air eliminator kits, but at $160 for two pieces of metal and a pulley, I thought that was a little steep. I then considered fabbing up my own, but decided with the time and effort it wasn't worth it either. What I did instead, was found a used air pump (I wanted to keep the original just in case) on ebay that I got shipped for $33. I opened it up and removed the fins and internal gears attached to the fins (if you open it up you'll see). The benefit to doing this it that it retains the alternator bracket in the stock location, which the eliminators don't do (causing twisting of the alternator if you don't custom fab some type of rear support). I swapped it out and removed all of the hoses and the plastic box that they connect into. All that's left is to get one more end cap for the exhaust manifold (I could only find one in my toolbox of leftover plumbing parts)
Overall I think it cleans it up nicely.
ps - I just zip tied the two connectors from the plastic box to another loom - is that what anyone else who did the mod has done???
Removed from inside air pump:
Photobucket
Cleaned up driver's side:
Photobucket
Cleaned up passenger's side (you can see the two connectors I zip tied):
Photobucket
Removed tubes:
Photobucket
Posted on: 2008/6/13 1:24
jimmers Re: Air pump gone...
Winnipeg, Manitoba Canada
211 Posts
One of the first things I did when I got my car was remove the air pump. It cleans up the engine bay quite a bit. I also just zip tied the cables under some wire loom.
Posted on: 2008/6/13 2:46
bogus Re: Air pump gone...
that thing is nothing but a failure waiting to happen.
I would save as much as possible, tho... if only for future originality concerns. By then, the C4 will no longer be daily drivers.
Posted on: 2008/6/13 3:23
Matatk Re: Air pump gone...
I hope you mean the original air system is a failure waiting to happen???
I'm saving it for S&G...I don't really care.
Posted on: 2008/6/13 3:32
yea, the original system is a failure point.
gutting the pump means it ain't doing nothing no mo...
Posted on: 2008/6/13 3:41
CentralCoaster Re: Air pump gone...
I just painted the alternator and air pump black, I don't like seeing all that crap anyways. Just the engine.
Posted on: 2008/6/13 18:21
NC Kid Re: Air pump gone...
North Carolina
1671 Posts
Im confused. Where does all this plumbing come into view? Anyone have a before/after pic?
Posted on: 2008/6/13 18:28
Not the best pic, but you can see the black airbox on the left of the screen (behind a/c compressor)that was removed - from there tubes run down the passenger side of the engine as well as in front of and across to the driver's side exhaust.
Photobucket
Another pic, pass side - here, the two hoses to the far right are smog hoses.
Photobucket
Posted on: 2008/6/13 19:23
North Carolina
1671 Posts
Thanks. What did you plug the big holes with on the passenger side?
Posted on: 2008/6/13 19:31
I don't really understand the question....There are two holes that need to be capped off - those are on the top of each exhaust manifold. Just buy the correct sized pipe cap and screw it on.
Posted on: 2008/6/13 19:38
Danspeed1 Re: Air pump gone...
Mooresville, North Carolina
1121 Posts
Or you could replace those old exhaust manifolds with a set of headers... that was my solution..
DG
Posted on: 2008/6/14 5:26
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
