190 user(s) are online (116 user(s) are browsing Forums)
Also known as the DIC.
DUBIE Head lights
NY
33 Posts
Ok what is the rotary noise I get when I shut-off the lights, I should add it never did it before----lasts about 20 seconds
Posted on: 2006/12/1 23:11
brut RE:Head lights
New Albany, IN
1308 Posts
What year was your C4?
Do they ever "stick" or have problems staying up?
Posted on: 2006/12/2 1:09
DUBIE Head Lights
NY
33 Posts
It's a 1991 vert and they operate just fine so far I get the same noise if just the parking lights are turned on-then off.
Posted on: 2006/12/2 16:27
bogus RE:Head lights
no clue. This is where the Factory Service Manual, available from www.helminc.com or via eBay, comes in real handy.
I have had it happen to mine, too... but I donno why.
Posted on: 2006/12/3 4:01
90EXPVette RE:Head lights
Martinez, Georgia
185 Posts
I know that sound...I had it when the bearings were going out. It lasted for a couple of months before the headlights wouldn't open all of the way. It's not a hard job to do just time consuming.
Posted on: 2006/12/4 12:32
red_johnny RE:Head lights
I would say it was the head lights but if it does it with the parking lights on is kinda of strange. I would want to point at a relay but since it does not stay on then I am not really sure what it could be.
Posted on: 2006/12/5 14:44
f451degrees RE:Head lights
anacortes, wa
9 Posts
my 91 vert does the same thing. I will be replacing the headlight bushings to see if that fixes it. ordered them yesterday from ecklers, $15 with shipping for both sides.
will keep ya posted
see ya on the road
Posted on: 2006/12/7 14:30
see ya on the road
anacortes, wa
9 Posts
fed ex delivered the new bushings to somewhere? not to me.
ecklers is sending a new set. fed ex wouldn't even call me back.
will keep you posted.
see ya on the road
Posted on: 2006/12/30 13:34
see ya on the road
DUBIE Head lights
NY
33 Posts
Just ordered some on E-Bay for $6.oo waiting for your results Thanks, ED
Posted on: 2006/12/31 1:25
anacortes, wa
9 Posts
Sorry it to so long, but I put the new bushings in yesterday. Very simple to do if everything goes right. But i had to snap of one of the screws that holds the motor to the gear casing on the dirvers side. So that took 2 extra hours to drill out the screw and replace with a bold and nut. Back togeather and no more noise. :thumbleft:
So on to the passenger side, figured it would take less than a 1/2 hour, now that i know how to do it. guess what, broke one of the screws that hold the motor to the gearcasing AGAIN...
knowing how to drill it out now, all backtogeather in an hour.
see ya on the road
tom
Posted on: 2007/3/24 2:14
see ya on the road
DUBIE Head Lights
NY
33 Posts
Tom, I installed mine about 2 weeks ago all went smooth except one of the limiters on the mechanism I installed backwords because everything on the other side is mirror and not the same. All works great just as you predicted. I guess these bushings are designed to take all the beating/sacrifice itself so the gears remain intact. Now for the EGR swap out and the new chip. Vette season is almost here!!!!
Posted on: 2007/3/25 0:05
