238 user(s) are online (153 user(s) are browsing Forums)
Ramrod C-6 Wheels
S. California
296 Posts
Will C-6 wheels fit on a 96 C-4 without too much hassle
Posted on: 2008/8/4 4:56
1996 LT-1
DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc.
bogus Re: C-6 Wheels
I think the offsets are different.
Posted on: 2008/8/4 5:55
CentralCoaster Re: C-6 Wheels
If you know the offsets and widths of the C6 wheels your using I can answer that question.
Posted on: 2008/8/4 6:19
Ramrod Re: C-6 Wheels
S. California
296 Posts
Offset being, the area where the wheel meets the hub and the area where the tire meet the wheel, offet is this distance?
Posted on: 2008/8/5 4:07
1996 LT-1
No. It's from the imaginary centerline of the wheel to the mounting surface on the hub. Usually easy to find. Both width and offset effect fitment.
I googled C6 wheel offset that and found this:
Base model front: 18x8.5 offset: +56 mm
Base model rear: 19x10 offset: +79 mm
The fronts will fit the same as your stock fronts.
The rears will tuck in 3/4" more than your stock rears and will need an adapter to look right.
Posted on: 2008/8/5 5:31
runner140 Re: C-6 Wheels
Ft. Lauderdale, Florida
721 Posts
On my least favorite place to shop, ebay, they sell spacer/adapters 3/4" for $59.00 plus $5.00 for shipping for two.
Find a seller with 100% positive feedback.
Posted on: 2008/8/5 11:51
If you get reproduction/chinese wheels, you sometimes can't use adapters that are thinner than the 1-1/8" stock wheel studs.
If you get OEM c6 wheels, you're fine.
Posted on: 2008/8/5 20:17
S. California
296 Posts
Fronts are 8.5 rears 10, thanks for all the information, so quick!
Posted on: 2008/8/6 5:18
1996 LT-1
S. California
296 Posts
After thinking about it for a bit, this is the only place where you can get the correct info so fast, thanks again.
Posted on: 2008/8/6 5:22
1996 LT-1
JonnyAngle Re: C-6 Wheels
Minneapolis, MN
151 Posts
go to lakeshorewheelandtire.com And click the "corvette specials."
Posted on: 2008/8/6 14:03
There's lots of misinformation on wheel fitment out there, so beware of what you hear elsewhere.
Posted on: 2008/8/6 17:31
