231 user(s) are online (203 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
kentucky_vetter Need Advice
somerset, ky
154 Posts
Friends 96 LT1. He has had the water pump and opti changed recently. Since then it has a miss after it warms up and smokes(black smoke) from the left bank. Since this started he has changed the Mass Air Sensor, plugs ,and wires. The only code it shows is Bank 1, Sensor 1. Today I changed the O2 Sensor for him and it still has the miss after it warms up. Any thoughts as what I should look for ?? Also when he changed the plugs the left bank plugs were shot but the right bank plugs looked like new.
Posted on: 2008/8/15 23:12
bogus Re: Need Advice
hm... I will have to check the book.
Can you give me the exact code?
Posted on: 2008/8/15 23:38
kentucky_vetter Re: Need Advice
somerset, ky
154 Posts
No I cant Andy. They used a scanner at auto zone and I only read the bank 1 , sensor 1 on the display. I didnt catch the actual code itself.
Posted on: 2008/8/15 23:48
1Fast04Vert Re: Need Advice
A leakdown test on the injectors and a compression test would be a good start.
Posted on: 2008/8/16 1:26
somerset, ky
154 Posts
Did a compression test on the left bank and all were 140 or better. Injector testing was my next step. Any good write-ups on injector testing ?
Posted on: 2008/8/16 1:44
Qack Re: Need Advice
274 Posts
95vette wrote:
A leakdown test on the injectors ...
I second that and would add that one or more might be partially clogged. You might be able to determine that with a scan tool, looking at the LT and ST corrections.
Posted on: 2008/8/16 2:06
a simple leak down test on the injectors is to put on a fuel pressure gauge and charge the system... see how long it takes for the fuel pressure to bleed off.
It could also identify a wacky fuel pump.
Another test is to remove the injector rails, charge the system and see if any injectors continue to leak. You can put little paper cups under the injectors and watch to see which ones leak or dribble some.
You may want to check out Mekanics thread, too. He has a good source for injectors at a great price.
Posted on: 2008/8/16 19:56
somerset, ky
154 Posts
Pulled the fuel rail last night and #7 was stuck wide open and flooding the cyclinder. Looks like he'll be buying a new set. I will have him get in touch with Mekanic. Thanks gurus!
Posted on: 2008/8/16 23:53
that answered that!
The GM/Multec injectors are ok, but not very durable.
Posted on: 2008/8/17 0:27
TommyT-Bone Re: Need Advice
33779 Posts
I'm a witness .....
Posted on: 2008/8/17 1:38
crash Re: Need Advice
WRIGHT CITY MO 63390
977 Posts
ME TOO
Posted on: 2008/8/17 2:41
pianoguy Re: Need Advice
Dang, that Bogus is good ;-)
Posted on: 2008/8/17 2:43
