bogus | I am off to fix the Jeep | ||
It needs new brakes.
Posted on: 2008/9/28 0:04
pianoguy | Re: I am off to fix the Jeep | ||
I let somebody else fix the other cars.
Posted on: 2008/9/28 0:50
Matatk | Re: I am off to fix the Jeep | ||
I feel your pain. I have to do the pads on the Xterra. I guess I should get to that sooner rather than later.
Matthew |
Posted on: 2008/9/28 0:54
bogus | Re: I am off to fix the Jeep | ||
welp... it looks like the front end has been updated... mine is a 93 2WD. The front bearings are supposed to be conventional bearings... well... the front end on this has the later style front end with bearing hubs.
I need to confirm the history... but all parts houses show bearings, whereas this has hubs. weird... |
Posted on: 2008/9/28 2:14
I checked... the front end is stock and correct.
Kragen (Parts America), Autozone, NAPA & Rock Auto are all WRONG! May I add that the Haynes manual is uber-wrong! The brake design changed mid-way through the 1992 model year (mine is a 1993). Kragen shows the change in 1994. Oopsie. Kragen is being nice about it and have the new parts, I hope... I will swap tomorrow. |
Posted on: 2008/9/28 3:23
djxib | Re: I am off to fix the Jeep | ||
Just curious - what's the practical difference between a conventional bearing and a bearing hub? I (successfully) did some work recently on the front bearing of my daughters 1998 grand cherokee, and I have no clue what type it is! Thanks
Posted on: 2008/9/28 12:49
This is a bearing hub:
The other style look like old school wheel bearings. |
Posted on: 2008/9/28 16:31
Thanks!! |
Posted on: 2008/9/28 20:57
CentralCoaster | Re: I am off to fix the Jeep | ||
One is serviceable and costs about $12, while the other is non-serviceable and costs $200. |
Posted on: 2008/9/29 3:48
yes.
brakes done. Feel about as good as brakes on a wagon... |
Posted on: 2008/9/29 4:53
