257 user(s) are online (204 user(s) are browsing Forums)
JimD 87/center air dam
NJ
14 Posts
When I bought this car over 2 years ago it had no center air dam. I recently bought a 3 piece set, put the ends on. Where the center dam bolts to, is broken off. Its a blk. plastic thingy. Does anyone know what's it called, and where I can purchase one, thanks Jim.
Posted on: 2008/9/30 0:34
anesthes Re: 87/center air dam
Boston, MA
Get some aluminum sheet from home depot and rivet it..
I was unable to order it. Discontinued.. They figure, how the heck are you going to break THAT off.. But mine was missing too.
I tell ya though. The way I have it set up now, don't see a temp higher than 194 or so. 180* thermostat, fans on at 190 off at 180.. There is a lot to be said about a properly configured air dam.
-- Joe
Posted on: 2008/9/30 1:27
CentralCoaster Re: 87/center air dam
On later years, they added a vertical bracket in the middle that attaches up top somewhere.
One of those bigmouth air dams would also be a place to attach it to, although that's an expensive way to fix it.
Posted on: 2008/9/30 6:36
convas Re: 87/center air dam
12 Posts
Posted on: 2008/9/30 8:10
Boston, MA
Hrmm. I needed one for a 91-96. Couldn't find one.
-- Joe
Posted on: 2008/9/30 12:01
Thanks for the link!
Posted on: 2008/9/30 16:18
