JimD | 87/center air dam | ||
When I bought this car over 2 years ago it had no center air dam. I recently bought a 3 piece set, put the ends on. Where the center dam bolts to, is broken off. Its a blk. plastic thingy. Does anyone know what's it called, and where I can purchase one, thanks Jim.
Posted on: 2008/9/30 0:34
anesthes | Re: 87/center air dam | ||
Get some aluminum sheet from home depot and rivet it.. I was unable to order it. Discontinued.. They figure, how the heck are you going to break THAT off.. But mine was missing too. I tell ya though. The way I have it set up now, don't see a temp higher than 194 or so. 180* thermostat, fans on at 190 off at 180.. There is a lot to be said about a properly configured air dam. -- Joe |
Posted on: 2008/9/30 1:27
CentralCoaster | Re: 87/center air dam | ||
On later years, they added a vertical bracket in the middle that attaches up top somewhere.
One of those bigmouth air dams would also be a place to attach it to, although that's an expensive way to fix it. |
Posted on: 2008/9/30 6:36
convas | Re: 87/center air dam | ||
I got mine used but Ecklers do list them.
http://www.ecklers.com/product.asp?pf_id=48994&dept_id=1430 http://www.ecklers.com/product.asp?pf_id=27128&dept_id=1430 |
Posted on: 2008/9/30 8:10
Hrmm. I needed one for a 91-96. Couldn't find one. -- Joe |
Posted on: 2008/9/30 12:01
Thanks for the link!
Posted on: 2008/9/30 16:18
