flyboy | increased ratio roller rockers | ||
I'm wondering how exactly does a higher ratio rocker arm affect the valvetrain? I'm assuming the pushrod is moved closer to the fulcrum of the rocker causing a higher valve lift. Does it also affect duration, reliability? How about valve noise due to a more aggressive opening and closing? I heard they give the engine a "lopey" idle. One company claims significant power with a 1.6 intake, 1.5 exhaust. What would they do for my mostly stock '91 L98 (straightend exhaust,T.C.3.07). Thats a pretty good chunk of change for something that may or may not do me some good. I won't be changing camshaft anytime soon. Any one have any experience on this?
Posted on: 2008/11/1 2:18
jsup | Re: increased ratio roller rockers | ||
More lift, faster ramp.
Shouldn't change the idle I hear 1.5 to 1.6 RRs are good for 10-15HP Don't forget the springs may have to be changed too. |
Posted on: 2008/11/1 2:22
AKS_Racing | Re: increased ratio roller rockers | ||
Probably more like 5-7HP on a stock cam vette. And you can run the factory springs, though your springs may be tired depending upon mileage.
Aaron |
Posted on: 2008/11/1 3:12
Thanks, I always suspected that 10-15 was over rated. No coil bind going to 1.6? Just wondering. |
Posted on: 2008/11/1 3:30
pr0zac | Re: increased ratio roller rockers | ||
i wouldn't do a split rocker ratio cause your cam already has a split. that is geared more for the old school cams that were like 280/280 .480/.480 and every new cam has a longer exhaust duration and usually a higher exhaustlift.
Posted on: 2008/11/1 12:30
flyboy | Re: increased ratio roller rockers | ||
Thanks for the input. I believe your right, P. According to my notes the cam specs are: @.050" lift in./ex. w/1.5 rockers .413"-.428", 202-207deg. lobe sep114.5.
Posted on: 2008/11/2 1:58
cuisinartvette | Re: increased ratio roller rockers | ||
The TPI guys that use the 1.6 typically like them on the intake only. For some reason putting them on the exhaust also tends to give it a slightly rougher idle than stock.
Honestly it isnt worth the money for what tiny gains you may get. Save up and do a H/C. The money spent for maybe 2-3deg dur. gain and what, maybe +.030 lift..Nah. |
Posted on: 2008/11/2 2:34
You will be redirected to that thread. Click here if your browser does not automatically redirect you. |
