156 user(s) are online (94 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
gkmccready Start Button doesn't turn off the car?
Redwood City, CA
28 Posts
Anybody else having times when you hit the stop button, the dash goes dark, the O light lights, but the engine keeps running?
It's happened to me a few times now; caught me out once because the radio was louder than the motor... thankfully there was nothing in front of the car to hit.
Posted on: 2008/11/8 20:24
biggrizzly Re: Start Button doesn't turn off the car?
I have a friend that his C6 was doing the same thing and also would not unlock from time to time. I will give him a holler and see what he says for you.
Posted on: 2008/11/8 20:31
Jeffvette Re: Start Button doesn't turn off the car?
There have been a few reported issues with the start button. What year is it?
Posted on: 2008/11/8 20:33
gkmccready Re: Start Button doesn't turn off the car?
Redwood City, CA
28 Posts
2006. No tune, no engine mods, not even an airfilter. Just suspension & brake mods.
Really started happening after the cars last trip to the dealership.
Posted on: 2008/11/8 20:48
Take it back and let them futz with it.
Posted on: 2008/11/8 21:30
Redwood City, CA
28 Posts
I have very little faith in the dealership these days, not to mention the price gouging on the parts. I'd prefer to walk in having some idea of what they should do or at least knowing whether this is a common problem they should know how to fix.
Posted on: 2008/11/8 21:46
Still not under warranty? PM me the last 8 of the vin and I'll run a vis report on it.
Posted on: 2008/11/8 23:08
Redwood City, CA
28 Posts
Had to replace the uprights because the LBJs had been run a little loose -- my bad when I installed the poly bushings and coilovers, I guess. But the wrench at the dealership tried to tell me it was so loose things had rubbed the rims... which was entirely false, the 11in wide front wheels rub the tie-rod at full lock.
It's all warranty all the time, including GMPP for this car. :-)
Posted on: 2008/11/9 1:06
Redwood City, CA
28 Posts
This is getting worse. Went out yesterday morning to start the car after the night before having the "stop doesn't stop" issue and found the car with a dead battery. Looks like my only choice is to strand the car with the dealership for some period of time. *sigh*
Posted on: 2008/11/15 18:31
CentralCoaster Re: Start Button doesn't turn off the car?
Did you try hitting the "stop" button?
Har har. Ok nevermind...
Posted on: 2008/11/16 3:22
Crazy8 Re: Start Button doesn't turn off the car?
Lake Worth, FL
125 Posts
Do you have your cell phone in your pocket with the fob? I have had weird issues whenever my cell is in the same pocket as my fob. Apparently, some cells can interfere with the signal of the fob. Just another idea.
Posted on: 2008/11/22 12:55
2008 Corvette - JSB, 3LT, Z51, NPP, U3U, A6
1986 Corvette - For Sale...PM me for info
1986 Monte Carlo SS - 400hp
2007 Dodge Charger Daytona R/T - Plum Crazy #981 of 1400
Redwood City, CA
28 Posts
Another good thought, but I actually carry the fob in my left pocket and phone in the right. Somebody elsewhere suggested my battery was having issues, which I couldn't really understand since hitting Stop means the alternator is running already for power, but I'm going to give it a shot. Since the battery had been drained twice there's a good chance it's junk anyway. I put a D34/78 Optima Yellow Top (in the '06) so we'll see if that makes all the issues go away...
Posted on: 2008/11/22 17:26
cuisinartvette Re: Start Button doesn't turn off the car?
Heard of this issue, have no real input just curious.
these new cars scare me, how the F are you supposed to fix them?
Posted on: 2008/11/22 18:03
Redwood City, CA
28 Posts
Well, put a brand new Yellow Top in the car on a suggestion from a friend. Stop issues persists and the battery was down again today when I went out just now to go for a ride. I guess the car is going to the dealership...
Posted on: 2008/11/30 22:37
CSS996 Re: Start Button doesn't turn off the car?
Mega Guru
Central PA
3644 Posts
Best of luck.
Let us know what they find.
Posted on: 2008/12/1 22:30
Currently "Between Vettes".
DouglasMariani Re: Start Button doesn't turn off the car?
Anaheim Hills,California
18 Posts
I would like to know what they found. My wife drives the 08 most of the time and this is a concern for me, especially when she goes on those 2 hours drives to see the kids.
Posted on: 2009/2/24 16:39
08 Coupe 6.2L/Auto
80 Coupe 350/Auto
68 Coupe 427/390 4spd
Redwood City, CA
28 Posts
The found a failed Body Control Module (BCM) and replaced it under warranty. It was one of those "we can't reproduce it, come get the car" and when I showed up to get the car the battery was dead. Then they started digging. Finally somebody noticed the power to the mirror wasn't shutting off... they traced it back to a failed electronics module...
Posted on: 2009/2/24 17:47
18 Posts
Thanks for the info. Its something for me to take note of. The battery went dead once last year for no reason (car was 2 weeks old at the time) but hasn't happened since.
Posted on: 2009/2/24 23:25
08 Coupe 6.2L/Auto
80 Coupe 350/Auto
