pr0zac | question | ||
is this too loud?
[URL=http://s228.photobucket.com/albums/ee176/pr0zac623/?action=view¤t=1107081759.flv][IMG]http://i228.photobucket.com/albums/ee176/pr0zac623/th_1107081759.jpg[/IMG][/URL] |
Posted on: 2008/11/8 2:24
biggrizzly | Re: question | ||
Its not playing for me in IE or Firefox
Posted on: 2008/11/8 2:32
jsup | Re: question | ||
Doesn't work for me either. |
Posted on: 2008/11/8 2:42
pr0zac | Re: question | ||
Posted on: 2008/11/8 2:47
Jeffvette | Re: question | ||
I hope that is not your car running, but some kids in the back ground beating on a metal garbage can.
Posted on: 2008/11/8 3:07
Schrade | Re: question | ||
Sounds powerful. Little overlap?
BRRR. Brutal. |
Posted on: 2008/11/8 4:57
Mekanic | Re: question | ||
I think you forgot about... 5 , yeah 5 plug wires there.
Posted on: 2008/11/8 5:32
happydad | Re: question | ||
It will be fine once it warms up
Posted on: 2008/11/8 10:02
86 Coupe,350 bored .040 over,Eagle Internals,Scorp RR.Crane Cam,Hedman Hedders,Holley Mani,TCI Trans,3:73 Rear, Demon Carb ,Hole in the hood Scooped and Lots of leaks(Horsepower) I forget :thumbleft: |
Posted on: 2008/11/8 18:53
OK My Bad :tongue3:
Posted on: 2008/11/9 1:49
bogus | Re: question | ||
uh... different... have you considered setting the idle up a little? To say 400 rpm?
Posted on: 2008/11/9 2:13
If you can get past the weed-whacker and the silly fat man, this is what mine sounded like. I think most of you have seen this silly clip, but sounds cool.
Posted on: 2008/11/9 2:46
Posted on: 2008/11/9 2:51
On a more serious note, mine was idling real low when I first started it up and I have no idea how, but the IAC valve was bad. I had two problems actually, the wrong knock sensors and a bad IAC valve. After I change the IAC, changed the knock sensors and re-adjusted the TPS it ran just fine. It is actually idling a little high now and I need to adjust it back down a tad.
Posted on: 2008/11/9 5:22
damn. Would I be right to assume that the lift on that cam is best measured with a yard stick? |
Posted on: 2008/11/9 7:14
VETTHRET | Re: question | ||
Sorry if I missed it but who tuned the car? Is that the factory tune in it still? I'd give the guys at PCMFORLESS a call to get at least a "baseline" tune. Those guys really know their stuff.
Here's mine with the first chip they sent me. It drives great and the throttle response is just incredible...........really crisp. |
Posted on: 2008/11/9 8:01
That sounds mean!! |
Posted on: 2008/11/9 8:03
its a pcmforless tune for my last setup right now. |
Posted on: 2008/11/9 15:18
