308 user(s) are online (276 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
« 1 (2)
LarryK87 RE:GP***Tapered Rear Wheel Bearing***GP
Port Charlotte, Fl
10 Posts
yep, packaging in excellant condition, looks like it was hand carried
maybe we should nominate steve as the official GP coordinator.
Three Cheers Steve
Posted on: 2007/11/26 12:34
jaa1992 RE:GP***Tapered Rear Wheel Bearing***GP
Stone Mtn, GA (near Atlanta)
187 Posts
Mine arrived over the weekend in good condition. However it did look like it had been handled roughly in its journy too me.
The outside of the box was a little banged up but the contents were in excellent condition.
Thanks!!!!!!
Posted on: 2007/11/26 18:05
1991zr1 Rear Wheel Bearings
3 Posts
I got my bearings yesterday.
One bearing has no play and the other has .015" play.
I would like to disassemble and reassemble them. Was the broken bearing cage in your photos unavoidable? I assume that during disassembly the outer seal broke the cage? Where was that large snap ring and what does it do? Will the manufacturer sell spare parts?
I'm thinking that if you disassemble the bearing, you can make a test setup like the mid 60's rear wheel bearings and measure the play and put in shims to space the bearings before doing the permanent installation.
Some people may get the idea that I wanted to disassemble the bearing to get rid of the play. That can be done without disassembly. I'm wondering if that won't even happen when you torque down the spindle. I do wonder also if some play is not a good thing. The reason I want to disassemble has nothing to do with play or the bearings. Maybe I should have asked if I could purchase the bearing not fully assembled or if they could vary the design for one customer. I have 5/16" spacers for my wheels and was considering taking the bearing apart and seeing if a machine shop could extend the part that goes into the wheel so the studs don't have to support all of the load. I don't really know if that is a concern because fricition between the wheel and spacer may provide support.
Posted on: 2007/11/28 8:36
tomtom72 RE:GP***Tapered Rear Wheel Bearing***GP
Mt Vernon, NY
2 Posts
This looks like it's been a total success!!!
I hope it's the first of many such successes!
Three cheers to Steve for doing a great job here!
I agree with bogus! My package arrived on friday and they are sweet! Thank you Steve for putting this deal together!
Posted on: 2007/11/28 10:09
JrRifleCoach Re: Rear Wheel Bearings
1524 Posts
One bearing has no play and the other has .031" play.
Thats a question for the guys at WBI www.wheelbearingsinc.com
If you want to cover postage and one dollar, ($10 MO to my mailing address) I'll gladly send you the parts for the disassembled bearing.
Steve
Posted on: 2007/11/29 2:26
1991zr1 RE:GP***Tapered Rear Wheel Bearing***GP
3 Posts
OK, I'll try to get a money order made this weekend or next week.
Posted on: 2007/11/29 8:46
Livin_the_dream RE:GP***Tapered Rear Wheel Bearing***GP
robesonia , pa
516 Posts
How about an update on this , please. I am interested in buying a set
It reminds me of an experience I had with front wheel bearings and half shafts. The torque of the half shaft nut gave the proper bearing preload . I had bought 2 and thought one was bad due to play. Went back to the parts store and most had play. Installed the bearing and have put over 25K on them in my suv
Thanks
Kevin
Posted on: 2007/12/3 18:36
bogus RE:GP***Tapered Rear Wheel Bearing***GP
Thanks!!!!!!
The conveyors will leave marks on boxes. It's perfectly normal.
Posted on: 2007/12/4 3:36
Hobbit RE:GP***Tapered Rear Wheel Bearing***GP
1 Posts
Hi Came over from 'the other place'.
Do you know how much to ship into the UK?
If not can you tell me the approx weight boxed so I can get my NY office to find out if they could ship them for me
Regards
Barry
Posted on: 2007/12/4 16:10
JrRifleCoach RE:GP***Tapered Rear Wheel Bearing***GP
1524 Posts
Regards, Barry
Shipping weight is 25 lbs. I ship via USPS Priority flat rate to the US. I did ship one set to Canada that cost approx $25 USD.
I'm OK with shipping out of country. It can be expensive. So to be fair to both of us, if you or any other C4Guru member that wants a set, you need to research the shipping costs ahead of time.
I can suggest using;
www.usps.com
www.ups.com
www.fedex.com
Calculate the rate based on
25 lbs 11"x 8 1/2"x 5 1/2"
11.36kg 28cm x 21.6cm x 14cm
From Sonora, CA 95370 to your location
Any documentation required needs to be emailed to me in advance.
Also, PayPal strips off 2.9% + $0.30 USD for each transaction.
Consequently using PayPal will increase the price by $8.00 USD
Thats all I can think of for now. I'll be starting another RWB GP link soon.
regards and Merry Christmas!
Steve
Posted on: 2007/12/4 21:07
3 Posts
Thanks
Kevin
I checked again and measured .015" play. I must have been pulling up on the bearing unevenly the first time. It will be some time before I install these bearings. If I take them apart to do modifications, the play that they have now really doesn't make any difference because it will be different when reassembled. I may try asking the manufacturer how much play is ideal. If the torque on the spindle nut is enough to pull in the bearings, the play before installation won't make a difference. If that is the case, the amount of torque used will be important. I seem to recall that the manual transmission cars need more torque when using stock bearings. I'm not sure if that will apply to these bearings.
Posted on: 2007/12/5 10:17
Slalom4me RE:GP***Tapered Rear Wheel Bearing***GP
Edmonton, AB
165 Posts
I have already been in touch with JrRifleCoach but thought that
I should post here that my bearings arrived in Canada on 11/29
while I was out of town.
The parts were well packed and USPS/CanPost were careful in
their handling of the parcel.
JRC, you have done a great job. I'm very pleased.
Posted on: 2007/12/9 0:36
Edmonton, AB
165 Posts
Did I see elsewhere that there is some prospect of front bearings becoming
available for C4's in the not-to-distant future?
If so, sign me up now for a GP when one becomes possible.
Posted on: 2007/12/9 0:40
kelley RE:GP***Tapered Rear Wheel Bearing***GP
thomasville ga
122 Posts
wish i had seen this last week, just paid 300+ each, ouch
Posted on: 2007/12/24 16:06
« 1 (2)
