c4joy1 | ecm eprom 85 | ||
I am building a stroker 383 and is thinking about the injectors. More volumen more air should also be connected to more fuel. I have stock 24 lps./hr. injectors and would like to upgrade to 30 lps./hr. injectors. Does anyone have experiance in burning a new e-prom to tell the system the larger injectors
regards Leif |
Posted on: 2009/1/15 22:38
bogus | Re: ecm eprom 85 | ||
A lot has to do with the specs.
Sure, a 383 is more engine, but you can get a lot from a 383 with 24lb injectors. Remember, the LT4 used 26lb injectors. Now, you do get into duty cycles and such... Where do you live? What is the big city near you? |
Posted on: 2009/1/16 4:57
captmike13 | Re: ecm eprom 85 | ||
Welcome aboard. Sorry I have no help to add.
Mike |
Posted on: 2009/1/16 6:12
oh, yea... dummy me...
Welcome aboard! |
Posted on: 2009/1/16 6:23
CentralCoaster | Re: ecm eprom 85 | ||
How high will it be revving? A 383 is only 10% more displacement. I would be very surprised if the 24# injectors can't be tuned to it easily.
Posted on: 2009/1/16 8:56
BeachBum | Re: ecm eprom 85 | ||
As food for thought, I ran 24lb injectors in my 85 corvette with a 383 to low 11's no problem.... it never even occured to me to go bigger. (These were FMS 24lb injectors)
There are a couple of other C4 owners that ran 24lb injectors to mid to low 10's with 434 motors. One of them is a tuner and stated the injectors were never static. Just food for thought... |
Posted on: 2009/1/17 17:17
863 cubic inches of C4 & C6 muscle C6 Corvette Z06 - Lemans Metallic Blue C4 Corvette 436 - Pure Black http://www.cardomain.com/ride/3933547 ... chevrolet-corvette/page-1 |
c4joy1 | Re: ecm eprom 85 | ||
Hi All
Thank you for the welcome and the thoughts about the injectors. Bogus i am from Denmark we have a lot of corvette entusiast here, infact we are organising a group to drive down with our corvettes to Le Mans it is more fun to go there with your own corvette. This year i get a chance to drive with my C4 on the actual track before the race startes, it is going to be great. I will use your advise and start with the 24 lb injectors and se howe it goes. see you out there Leif |
Posted on: 2009/1/17 21:41
Wow! Another European member! That's great!
There is an old friend from another forum who has a 96 GS and a 90(?) Ferrari 348. You will want to get the computer tuned... you may want to check out PCM's for Less... http://www.pcmforless.com/ IIRC, they can even provide you with a new chip with the programming already updated for your needs. Short of putting this car on a dyno and getting it done in real time, a near miss tune isn't all that bad. The computer can adapt, it just needs the base tables modified. |
Posted on: 2009/1/17 22:08
Schrade | Re: ecm eprom 85 | ||
Welcome to the boards there! I think I've read that 30's might be too high for an L98. Had something to do with spec fuel pressure. |
Posted on: 2009/1/18 2:47
Hi Bogus
That would be Lars, i know the guy, he is also a member of the Danish Corvette Club. Regarding the injectors and the ECM, i think i will keep the 24 lb injectors, and in near future i will change the ECM, with a full computorized solution and at that time i can control everything myself. I will be back with an update when i crank the engine. Leif |
Posted on: 2009/1/18 15:45
Lars is the man! I forgot to add his name... I really need to invite him over here.
I would keep the injectors. I would actually consider this setup: http://www.eficonnection.com/eficonnection/coil_per_cylinder.aspx You see, as I understand it, the aftermarket computers just do not have the drivability that the factory units have. At the same time, a later LSx computer can be updated via a handheld device or laptop computer. GM has put a lot of time, money and research into making their PCMs that much better. |
Posted on: 2009/1/18 19:12
