179 user(s) are online (91 user(s) are browsing Forums)
tjpreul SES light
On my '03 S10 the SES light has been on for a while (about a year). The shop had told me it was the gas cap code, so I didn't worry about it. Since then I have switched shops, due to an outrageous quote. I recently had to put on new front bearings, so I had my friend put them on (he's a mechanic a dealership). He told me that both bank 1 O2 sensors were bad, which they probably went bad in the past year, but there was no gas cap code in the system. I replaced the sensors, and no more code.
Posted on: 2009/1/22 20:21
pianoguy Re: SES light
It's hard to find good help anymore ;-)
Posted on: 2009/1/22 22:42
Matatk Re: SES light
Glad it worked out. That's why it's nice that autozone does it for free, just to double check
Posted on: 2009/1/22 23:10
bogus Re: SES light
Autozone as stopped that around here.
Posted on: 2009/1/23 4:43
BillH Re: SES light
Hear too.
So, I spent $150 for a ODB2 scanned because the Silverado had a SES lite.
I got a code for the secondary air sys. I figured that I'd reset the codes and see what happens.
Now after 1500 mi., I get no SES and gat no codes but 2 of the 9 "emmission readiness monitors" aren't complete. "Drive cycles need to be run to complete all the supported monitors to meet minimum required specs for Fed emissions". It's been that way for 2 months.
And the Helm's $135. Crap.
Posted on: 2009/1/23 14:40
Trae1976 Re: SES light
Johnson City, TN
832 Posts
Interesting. My wife's car has been showing the gas cap code for several months. I reset it, and its fine for a few weeks, then it shows up again. I may have to look into the O2 sensors.
Posted on: 2009/1/23 17:41
tjpreul Re: SES light
I think having the proper scan tool makes a big difference.
Posted on: 2009/1/23 19:03
happydad Re: SES light
northern Ill
151 Posts
I'd just Pull the bulb :evil3:
Posted on: 2009/1/23 19:21
