191 user(s) are online (132 user(s) are browsing Forums)
Assembly Line Diagnostic Link
BrianCunningham caught a virus off the 'other forum'
Makes you wonder about their vendors
I save some threads while surfing under WindowsXP
When I booted up under Linux today it's virus scanner picked up the following
Photobucket
Posted on: 2009/1/29 17:52
pianoguy Re: caught a virus off the 'other forum'
Posted on: 2009/1/29 18:50
Schrade Re: caught a virus off the 'other forum'
Photobucket
Was it cloggin' up the CPU in sys monitor?
I think someone targeted you. You have to deliberately attach scripts to a target; it cannot happen randomly to just one UNIX/LINUX OS I'm pretty sure. Where's bmwgsa there?
Posted on: 2009/1/30 3:28
CentralCoaster Re: caught a virus off the 'other forum'
what is "scirev"? Is that a page your browser downloaded against your will?
Posted on: 2009/1/30 4:14
BrianCunningham Re: caught a virus off the 'other forum'
I think it only did it if you did a "save as" on the thread.
It saved the html file, and created a folder to hold the images, javascripts etc.
The files were in that folder.
I used to save the 'printable' versions of the file.
But when you look at the printable versions now, the images aren't there
Posted on: 2009/1/30 4:41
FYI
[QUOTE]savewave;
I checked with the tech folks at IB and was told this is not a malicious script or virus, but rather a plug-in used to track links to sites that place advertising on Corvetteforum.
:cheers:[/QUOTE]
Posted on: 2009/1/31 16:11
FYI
[QUOTE]savewave;
:cheers:[/QUOTE]
Yup - deliberate targeting, of sorts...
Before you click on a page that smells like
do a right click. View page source, and see what's there. You'll be surprised. It's like watchin' meatpackers make a hot dog. And if you like hot dogs, DON'T DO IT.
And if you don't, DON'T DO IT IN WINDOWS!!!
Posted on: 2009/2/1 5:24
