216 user(s) are online (131 user(s) are browsing Forums)
84bluec4 Snow Tires?
Grass Lake, Michigan 49240
65 Posts
Think if I put snow tires on the Vette I can go for a drive??
jpg  snowvette.jpg (55.24 KB)
722_497b2a2e73619.jpg 604X453 px
Posted on: 2009/1/24 14:48
M Moore
1984 Lt blue/Med blue, z51, automatic, 3.07
350 crossfire
blue cloth interior, Bose stereo,
everything still stock (for now)
pianoguy Re: Snow Tires?
I saw a C5 out the other day, all slathered with slush and salt spray. I have the itch, too, but I'll be waiting until March to bring my car home.
Looks like yours has a nice hibernating spot!
Posted on: 2009/1/24 15:30
Danspeed1 Re: Snow Tires?
Mooresville, North Carolina
1121 Posts
In short... Yes...
I had snow tires on mine and we used to drive it all winter. Had it in up to a half a foot of snow, and it just dug and went!
Funny thing, I happen to know somebody who has a set of wheels and snow tires for sale.
[IMG]http://i142.photobucket.com/albums/r97/BG528/Nastyweather.jpg[/IMG]
DG
Posted on: 2009/1/24 17:29
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
84bluec4 Re: Snow Tires?
65 Posts
It works until I get its new home built this summer. That ground is cold!
Posted on: 2009/1/25 12:06
M Moore
350 crossfire
65 Posts
Danspeed1 wrote:
In short... Yes...
DG
The biggest problem I was having was getting the snow knocked down far enough to clear the air damn up front. That's about as far as I could shovel before all the packed ice. The one time I had to drive in the snow it was a white knuckle experience all the way but tires do make the difference.
Posted on: 2009/1/25 12:11
M Moore
350 crossfire
1121 Posts
If you could believe it, my Impala is seriously worse. That's one of the reasons I also have the Monte Carlo. Next year I will probably get snow tires for the C6, but for the time being it is useless in the snow with the summers on it.
DG
Posted on: 2009/1/26 18:07
1996 Ford Explorer
2009 Cadillac CTS-v
65 Posts
DG
Wow, I thought the Impala would be better then the Vette.
I know my 1/2 ton short box 4x2 is a real joke in any snow.
Posted on: 2009/1/29 1:42
M Moore
350 crossfire
BrianCunningham Re: Snow Tires?
If your serious, which I doubt
I've got snow on the 16in rims, were hard to get at the time.
17's are actually easier to get.
Just make sure you WASH it afterwards
Photobucket
BTW
That portable garage looks like it needs a little attention.
Neighbor's racecar got all messed up when his collapsed
Posted on: 2009/1/29 2:21
65 Posts
I was working on getting all the snow off. I had to re-tighten everything after all that heavy snow.
When I was assembling it I was climbing all over the frame. It is pretty solid believe it or not.
Posted on: 2009/2/10 0:56
M Moore
350 crossfire
