152 user(s) are online (82 user(s) are browsing Forums)
Josh TFS head information for the AFR/TFS head comparison
I've posted this in a couple different spots, but I think it deserves it's own post.
See the whole comparison thus far here:
http://www.corvette-guru.com/modules/ ... php?topic_id=7225&forum=1
I got the information regarding the testing of my TFS 195 CC heads. Here's the E-mail I got from the shop:
Hi Josh,
They did arrive and I already have a bunch of information for you.
First off they are 100% ported, not just a bowl cleanup like you had alluded to. Guides are narrowed and necked downed nicely and this head had been ported from one end to the other. I might add it was done by someone who looked like they knew what they were doing and had a very neat hand (the walls were straight and the overall execution was certainly above average). The porting might not have been as obvious to you because the heads were glass-beaded when they were freshened disguising some of the finish sandroll marks that are clearly evident when you look closely.
Finished intake port volume 205 cc’s
Intake Flow
.200 @ 140
.300 @ 200
.400 @ 245
.500 @ 274
.550 @ 280
.600 @ 282
Exhaust port finished volume 76 cc’s
.200 @ 108
.300 @ 144
.400 @ 176
.500 @ 190
.600 @ 204
Combustion chamber volume is very small @ 57 cc’s (just under actually like 56.8 actually)
The TFS heads are much better heads than I thought, so it will definitely make this an interesting test. The idea of AFR winning by a landslide doesn't seem as likely to me now as it did a couple weeks ago.
Time will tell. The short block is in the car as of tonight, so the project is moving along.
Posted on: 2009/2/19 3:16
BeachBum Re: TFS head information for the AFR/TFS head comparison
751 Posts
Thanks for sharing Josh....
Why would somebody try to hide the porting work they did on the cylinder heads ? Seems like a silly waste of time.... its not like anybody will check once they're on the motor....
Posted on: 2009/2/19 4:38
C4 Corvette 436 - Pure Black
Josh Re: TFS head information for the AFR/TFS head comparison
I don't think anyone was trying to hide anything. I bought the heads used, and before installing them I had them freshened by a shop. I never saw the heads before the bead blasting.
Posted on: 2009/2/19 4:52
rickreeves1 Re: TFS head information for the AFR/TFS head comparison
New Orleans
96 Posts
Posted on: 2009/2/19 21:11
1989GTA Re: TFS head information for the AFR/TFS head comparison
61 Posts
Thanks again for doing the test. Looks like a set of well ported Trickflows against out of the box AFR's. It is going to be an interesting dyno test.
Posted on: 2009/2/20 1:37
rklessdriver Re: TFS head information for the AFR/TFS head comparison
I've hidden lots of port work...
There is a cottage industry built on porting heads with acid and/or shot peening hand port work (afterwards) to make them look "as cast" in the oval track and NHRA/IHRA Stock Eliminator world.
I know neither is something someone would use a set of TFS heads on but still you never know.... When I first started out with acid porting and other cover up work, I practiced on all kinds of stock SBC and SBF heads we had laying around the shop.
Some of those heads I experimented on ended up in truck and van motors we were contracted to build for a funiture moving business. I keep thinking that one day someone is going to take one of those motors apart and wonder how in the heck a set of stock looking SBC 882 smog heads have 185cc intake runers.....
-Josh
With numbers like that, you have a pretty darn good set of TFS heads. As long as the air speed isn't out of wack anywhere they will most likely give the AFR's a good run for their money on the dyno.
Posted on: 2009/2/20 1:53
CentralCoaster Re: TFS head information for the AFR/TFS head comparison
Sheesh. While you're at it, did you restamp the serial number pads on the blocks?
Posted on: 2009/2/20 2:09
751 Posts
Thats some funny stuff reckless !! LOL... so you want your new furniture delivered right now sir ? You betcha !!
Posted on: 2009/2/20 3:03
Yeah, I had no idea the TFS heads were what they are. When I bought them I got a receipt from the previous owner that said:
"Gasket match / Chamber clean - $300."
I guess the previous owner got a good deal.
Posted on: 2009/2/20 22:53
