335 user(s) are online (298 user(s) are browsing Forums)
skirlin Help! What size is the spindle nut?
Caledonia Michigan
277 Posts
I started the tear down for replacing the bearings and ujoints and ran into a problem. I have a 1992 coupe. I don't have a socket the right size for the spindle nut. 1 1/4" is too small and 1 1/2" is too big. I will be going to the auto parts place tomorrow to get the spindle washers and will pick up a socket when I am there. Any help would be greatly appreciated. Thanks, Dave.
Posted on: 2009/3/20 3:31
vetteoz Re: Help! What size is the spindle nut?
36mm
Posted on: 2009/3/20 6:19
bogus Re: Help! What size is the spindle nut?
Also, when you retighten the spindle nut, do so to 200 ft-lbs. It's a bitch... I know...
You will also need to get a couple extra T-55 torx sockets. I recommend this because those suckers can be uber-tight... and it's not uncommon to break a socket or two.
It might help if you spray the outside of those bolts with a PB Blaster type of penetrating oil.
Posted on: 2009/3/20 12:44
CentralCoaster Re: Help! What size is the spindle nut?
Yup, 36mm. Crack it loose before you remove the ebrake cable. The posi alone won't keep it from spinning.
Posted on: 2009/3/20 15:07
WW7 Re: Help! What size is the spindle nut?
Almost Heaven WV
268 Posts
If you want a cheap 36mm socket go to Advance Auto, they have one for about $6.00, since its not used much these work fine...WW
Posted on: 2009/3/20 22:36
