173 user(s) are online (119 user(s) are browsing Forums)
apeacefulstorm speedometer adjustment
Huntsville, Alabama
147 Posts
I went with wider tires on the rear, will the speedometer need to be adjusting? With this wheel and tire package I cannot believe I am going as fast as the speedo readout..... this morning to work I am cruising along and the speedo is reading 89 mph and I am like, "no way..." So its either the quality of the new tires or the speedo is off.... what do you think?
Posted on: 2007/12/27 12:57
CasetheCorvetteman RE:speedometer adjustment
What year model mate? If its 93, TopTechx6 has been through this top to toe ;)
Posted on: 2007/12/27 13:00
toptechx6 RE:speedometer adjustment
south Florida
362 Posts
Wider shouldn't really make any difference, height will change the circumference and that does affect the speedo, most tire size changes however have minimal effect.
Here is a calculator that may help, not my work, I believe credit goes to Corvette Kid.
http://webpages.charter.net/khasting/ ... /techinfo/speedocalc.html
Posted on: 2007/12/27 13:31
apeacefulstorm RE:speedometer adjustment
Huntsville, Alabama
147 Posts
its a 93....
Posted on: 2007/12/27 13:37
Huntsville, Alabama
147 Posts
thanks for the help... had me concerned for a moment... based on the calculator you are right, the difference is minimal... so I am not going to worry about it...
Posted on: 2007/12/27 13:38
its a 93....
If you had a 94 or 95 i couldve got it dead perfect for you from sitting right here!!
Posted on: 2007/12/27 13:42
Huntsville, Alabama
147 Posts
here is another calculator that calculates speedo readings based on tire size....
http://www.paspeedo.com/calculator.htm
Posted on: 2007/12/27 13:57
VtVette RE:speedometer adjustment
Las Vegas, NV
357 Posts
Just an FYI I went from 28" to 35" tall tires on my Chevy truck and it only made a 4mph difference. I figured it would be a much bigger difference than that.
Posted on: 2007/12/28 2:40
Brian
VTvette
CentralCoaster RE:speedometer adjustment
That would make a 25% difference. That's huge. So I guess if you were driving 16 mph, you'd be reading 4mph high. :tongue:
Posted on: 2007/12/29 7:23
