247 user(s) are online (169 user(s) are browsing Forums)
JonnyAngle how to add ATF
Minneapolis, MN
151 Posts
I just cheked my ATF, and the dipstick says I'm 1qt low. But where do I pour it in? .86 automatic
Thanks,
Jack
Posted on: 2009/7/18 17:43
jhammons01 Re: how to add ATF
If there is no "Funny Vette" issues....you just use a funnel with a small lower portion and pour the ATF in the same hole the Dipstick comes out of.
That is standard for US built Auto tranny's for decades.
Posted on: 2009/7/18 17:58
vetteoz Re: how to add ATF
Make sure you check fluid level with trans hot, in park ,with engine running.
Posted on: 2009/7/19 7:37
